Dashboard data not showing
i have 4 graylog server nodes in a cluster.
on one of them i cannot see the dashboard data and instead i see “N/A”
How is the configuration of the problematic Graylog node different from the working Graylog nodes?
configuration is the same
Please, don’t provide too many details like, for example, the actual configuration!
# If you are running more than one instances of graylog-server you have to select one of these
# instances as master. The master will perform some periodical tasks that non-masters won't perform.
is_master = false
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting graylog-server from init scripts or similar.
node_id_file = /var/opt/graylog/graylog-server-node-id
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
password_secret = [redacted]
# the default root user is named 'admin'
root_username = admin
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
root_password_sha2 = [redacted]
# Default is empty
#root_email = ""
# The time zone setting of the root user.
# Default is UTC
root_timezone = Asia/Jerusalem
plugin_dir = /opt/graylog/plugin
# REST API listen URI. Must be reachable by other graylog-server nodes if you run a cluster.
rest_listen_uri = http://0.0.0.0:9000/api
# Web interface listen URI
web_listen_uri = http://0.0.0.0:9000/
# REST API transport address. Defaults to the value of rest_listen_uri. Exception: If rest_listen_uri
# is set to a wildcard IP address (0.0.0.0) the first non-loopback IPv4 system address is used.
# If set, his will be promoted in the cluster discovery APIs, so other nodes may try to connect on
# this address and it is used to generate URLs addressing entities in the REST API. (see rest_listen_uri)
# You will need to define this, if your Graylog server is running behind a HTTP proxy that is rewriting
# the scheme, host name or URI.
# Web interface endpoint URI. This setting can be overriden on a per-request basis with the X-Graylog-Server-URL header.
# Default: $rest_transport_uri
# Enable CORS headers for REST api. This is necessary for JS-clients accessing the server directly.
# If these are disabled, modern browsers will not be able to retrieve resources from the server.
# This is disabled by default. Uncomment the next line to enable it.
rest_enable_cors = true
# Enable GZIP support for REST api. This compresses API responses and therefore helps to reduce
# overall round trip times. This is disabled by default. Uncomment the next line to enable it.
#rest_enable_gzip = true
# Enable HTTPS support for the REST API. This secures the communication with the REST API with
# TLS to prevent request forgery and eavesdropping. This is disabled by default. Uncomment the
# next line to enable it.
#rest_enable_tls = true
# The X.509 certificate file to use for securing the REST API.
#rest_tls_cert_file = /path/to/graylog2.crt
# The private key to use for securing the REST API.
#rest_tls_key_file = /path/to/graylog2.key
# The password to unlock the private key used for securing the REST API.
#rest_tls_key_password = secret
# The maximum size of a single HTTP chunk in bytes.
#rest_max_chunk_size = 8192
#rest_max_header_size = 8192
# The maximal length of the initial HTTP/1.1 line in bytes.
#rest_max_initial_line_length = 4096
# The size of the thread pool used exclusively for serving the REST API.
#rest_thread_pool_size = 16
# The size of the worker thread pool used exclusively for serving the REST API.
#rest_worker_threads_max_pool_size = 16
#no_retention = false
elasticsearch_shards = 4
elasticsearch_replicas = 1
# be enabled with care. See also: http://graylog2.org/resources/documentation/general/queries
allow_highlighting = true
# requires authentication.
elasticsearch_hosts = http://172.25.230.30:9200,http://172.25.230.31:9200,http://172.25.230.32:9200,http://172.25.230.33:9200
# Maximum amount of time to wait for successfull connection to Elasticsearch HTTP port.
# be tore down.
elasticsearch_max_total_connections = 20
# elasticsearch server).
elasticsearch_max_total_connections_per_route = 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
elasticsearch_discovery_enabled = true
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
#elasticsearch_discovery_filter = rack:42
#elasticsearch_discovery_frequency = 30s
# Elasticsearch documentation: http://www.elasticsearch.org/guide/reference/index-modules/analysis/
# Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
# calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
# Default: 1m
#elasticsearch_request_timeout = 1m
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
# Start server with --statistics flag to see buffer utilization.
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the disk based message journal.
message_journal_enabled = false
# The directory which will be used to store the message journal. The directory must me exclusively used by Graylog and
message_journal_dir = /var/opt/graylog/data/journal
message_journal_max_size = 1gb
async_eventbus_processors = 2
# stream_processing_timeout = 2000
# stream_processing_max_faults = 3
# Length of the interval in seconds in which the alert conditions for all streams should be checked
# and alarms are being sent.
alert_check_interval = 60
# Since 0.21 the graylog server supports pluggable output modules. This means a single message can be written to multiple
# messages end up. This setting is specified in milliseconds.
#stale_master_timeout = 2000
# shutdown_timeout = 30000
# MongoDB Configuration
mongodb_uri = mongodb://172.25.230.30:27017/graylog
# Raise this according to the maximum connections your MongoDB server can handle if you encounter MongoDB connection problems.
mongodb_max_connections = 100
# If mongodb_max_connections is 100, and mongodb_threads_allowed_to_block_multiplier is 5, then 500 threads can block. More than that and an exception will be thrown.
# http://api.mongodb.org/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Drools Rule File (Use to rewrite incoming log messages)
# See: http://graylog2.org/resources/documentation/general/rewriting
# Email transport
transport_email_enabled = false
transport_email_hostname =
transport_email_port = 587
transport_email_use_tls = true
transport_email_use_ssl = true
transport_email_auth_username =
transport_email_auth_password =
transport_email_from_email =
transport_email_web_interface_url =
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
# HTTP proxy for outgoing HTTP calls
# Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
# cycled indices.
#disable_index_optimization = true
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
# Disable the index range calculation on all open/available indices and only calculate the range for the latest
# index. This may speed up index cycling on systems with large indices but it might lead to wrong search results
# in regard to the time range of the messages (i. e. messages within a certain range may not be found). The default
# is to calculate the time range on all open/available indices.
#disable_index_range_calculation = true
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
# Enable collection of Graylog-related metrics into MongoDB
#enable_metrics_collection = false
# Disable the use of SIGAR for collecting system stats
#disable_sigar = false
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
dashboard_widget_default_cache_time = 10s
# Automatically load content packs in "content_packs_dir" on the first start of Graylog.
content_packs_loader_enabled = true
# The directory which contains content packs which should be loaded on the first start of Graylog.
content_packs_dir = /opt/graylog/contentpacks
# A comma-separated list of content packs (files in "content_packs_dir") which should be applied on
# the first start of Graylog.
content_packs_auto_load = grok-patterns.json,content_pack_appliance.json
What does that mean exactly?
What’s in the logs of the Graylog node and the Elasticsearch nodes at the time the problem is happening?
logs from server
Widget type <org.graylog.plugins.quickvaluesplus.widget.strategy.QuickValuesPlusWidgetStrategy> not found!
2017-11-08_11:08:01.86109       at org.graylog2.dashboards.widgets.WidgetStrategyFactory.getWidgetForType(WidgetStrategyFactory.java:46) ~[graylog.jar:?]
2017-11-08_11:08:01.86213       at org.graylog2.dashboards.widgets.WidgetResultCache.getComputationResultForDashboardWidget(WidgetResultCache.java:52) ~[graylog.jar:?]
2017-11-08_11:08:01.86439       at org.graylog2.rest.resources.dashboards.DashboardWidgetsResource.widgetValue(DashboardWidgetsResource.java:219) ~[graylog.jar:?]
2017-11-08_11:08:01.86489       at sun.reflect.GeneratedMethodAccessor88.invoke(Unknown Source) ~[?:?]
2017-11-08_11:08:01.86707       at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_131]
2017-11-08_11:08:01.86736       at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_131]
2017-11-08_11:08:01.86817       at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[graylog.jar:?]
2017-11-08_11:08:01.87007       at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[graylog.jar:?]
2017-11-08_11:08:01.87465       at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[graylog.jar:?]
2017-11-08_11:08:01.87552       at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$TypeOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:205) ~[graylog.jar:?]
2017-11-08_11:08:01.87767       at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[graylog.jar:?]
2017-11-08_11:08:01.87806       at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[graylog.jar:?]
2017-11-08_11:08:01.88018       at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[graylog.jar:?]
2017-11-08_11:08:01.88057       at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[graylog.jar:?]
2017-11-08_11:08:01.88126       at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [graylog.jar:?]
2017-11-08_11:08:01.88271       at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [graylog.jar:?]
2017-11-08_11:08:01.88316       at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [graylog.jar:?]
2017-11-08_11:08:01.88447       at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [graylog.jar:?]
2017-11-08_11:08:01.88566       at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [graylog.jar:?]
2017-11-08_11:08:01.88655       at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [graylog.jar:?]
2017-11-08_11:08:01.88781       at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [graylog.jar:?]
2017-11-08_11:08:01.88820       at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [graylog.jar:?]
2017-11-08_11:08:01.88888       at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [graylog.jar:?]
2017-11-08_11:08:01.89117       at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:384) [graylog.jar:?]
2017-11-08_11:08:01.89242       at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:224) [graylog.jar:?]
2017-11-08_11:08:01.89288       at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:176) [graylog.jar:?]
2017-11-08_11:08:01.89399       at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_131]
2017-11-08_11:08:01.89582       at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_131]
2017-11-08_11:08:01.89866       at java.lang.Thread.run(Thread.java:748) [?:1.8.0_131]
2017-11-08_11:08:01.89916 ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource% java.lang.IllegalArgumentException: Widget type <org.graylog.plugins.quickvaluesplus.widget.strategy.QuickValuesPlusWidgetStrategy> not found!
2017-11-08_11:08:01.89974       at org.graylog2.dashboards.widgets.WidgetStrategyFactory.getWidgetForType(WidgetStrategyFactory.java:46) ~[graylog.jar:?]
2017-11-08_11:08:01.90119       at org.graylog2.dashboards.widgets.WidgetResultCache.getComputationResultForDashboardWidget(WidgetResultCache.java:52) ~[graylog.jar:?]
2017-11-08_11:08:01.90166       at org.graylog2.rest.resources.dashboards.DashboardWidgetsResource.widgetValue(DashboardWidgetsResource.java:219) ~[graylog.jar:?]
2017-11-08_11:08:01.90335       at sun.reflect.GeneratedMethodAccessor88.invoke(Unknown Source) ~[?:?]
2017-11-08_11:08:01.90424       at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_131]
2017-11-08_11:08:01.90642       at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_131]
2017-11-08_11:08:01.90870       at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[graylog.jar:?]
2017-11-08_11:08:01.90947       at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[graylog.jar:?]
2017-11-08_11:08:01.91303       at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[graylog.jar:?]
2017-11-08_11:08:01.91347       at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$TypeOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:205) ~[graylog.jar:?]
2017-11-08_11:08:01.91572       at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[graylog.jar:?]
2017-11-08_11:08:01.91635       at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[graylog.jar:?]
2017-11-08_11:08:01.91914       at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[graylog.jar:?]
2017-11-08_11:08:01.92030       at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[graylog.jar:?]
2017-11-08_11:08:01.92235       at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [graylog.jar:?]
2017-11-08_11:08:01.92305       at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [graylog.jar:?]
2017-11-08_11:08:01.92634       at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [graylog.jar:?]
2017-11-08_11:08:01.92689       at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [graylog.jar:?]
2017-11-08_11:08:01.92795       at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [graylog.jar:?]
2017-11-08_11:08:01.92985       at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [graylog.jar:?]
2017-11-08_11:08:01.93179       at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [graylog.jar:?]
2017-11-08_11:08:01.93232       at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [graylog.jar:?]
2017-11-08_11:08:01.93328       at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [graylog.jar:?]
2017-11-08_11:08:01.93508       at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:384) [graylog.jar:?]
2017-11-08_11:08:01.93726       at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:224) [graylog.jar:?]
2017-11-08_11:08:01.93774       at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:176) [graylog.jar:?]
2017-11-08_11:08:01.94876       at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_131]
2017-11-08_11:08:01.94918       at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_131]
2017-11-08_11:08:01.95060       at java.lang.Thread.run(Thread.java:748) [?:1.8.0_131]
You have to install plugins on all Graylog nodes in the cluster.
i did it and it is working fine
thanks
