Hi I am newbie and I have question about the CPU problem from devices connected to Graylog server.
I have a question that if CPUs from other devices load high (99-100%), Graylog will still be able to receive logs from these devices ?
Thank you.
Thank you.
As long as Graylog and the underlying system is configured correctly, it will receive and attempt to process all the messages sent to it. If the sending system is unable to generate the message or send it for some other reason… Graylog obviously can’t do anything about that.
Or am I misunderstanding your question?
