Counting lines with specific field value
I have log lines like theses ones:
{"app":"app1", "needrestart":1}
{"app":"app2", "needrestart":0}
{"app":"app3", "needrestart":0}
{"app":"app4", "needrestart":1}
And I want to make a single number dashboard to tell me there are 2 apps to restart. It seems very simple but I can’t figure how to achieve this. Note: app can have multiple entries, but only the most recent one must be used.
Thanks for your help !
Mat
Hi @mig
  1. seperate your logs into machine-readable fields. Field “app” and field “needrestart”.
  2. filter for needrestart:1
  3. add a widget counting the card() of the field app. This will tell you how many different values exist for the field “app”. This is the number you are looking for.
cheers,
ihe
It works, thanks a lot. For those who don’t know (like me), the card() function means “cardinality” :smiley:
Bye.
