Count unique field values using API
Hello, we log all user requests to our site and I’m trying to figure out via the API how many unique users have performed a specific action over the past 60 seconds.
So once I have a query for the subset I need via search/universal/relative API, is there a way to get the API to then give me a count of how many unique userId values exist in that subset?
It seems like https://github.com/Graylog2/graylog2-server/issues/3649 is related but I’m not sure how to do this via API.
Hey @irontoby,
You could call this:
https://graylog.example.com/api/search/universal/relative/terms?query=*&range=300&field=userId&order=userId:desc&size=50
query = your query
range = range in seconds
field = field that should be used by the term aggregation
order = Order of results, sorted by which field and ascending/descending
size = how many terms to report
Example response:
    "time": 235,
    "terms": {
        "user1": 100273,
        "user2": 4,
        "user3": 4,
        "user4": 794,
        "user5": 1,
        "ext-user1": 7,
        "baduser": 17570,
        "user1337": 123931,
        "user6": 4475,
        "ext-user2": 4,
        "ext-user3": 4
    }, <<< OUTPUT TRUNCATED for readability >>>
Only be aware, that even though the query was performed using your order instruction, the returned values are not in order.
Greetings,
Philipp
Thanks for the answer Philipp, I was unaware of the “terms” search, and in fact I’m getting a 403 Unauthorized when I try to run that query (which I’m guessing is why it wasn’t in my API browser). I’ll get w/ our admin and get that fixed.
This looks very close to what I need, I don’t suppose it’s possible to then count up the various userId terms and return just a single count?
Of course that’s possible :slight_smile:
https://graylog.example.com/api/search/universal/relative/stats?query=*&range=300&field=userId
  "time": 390,
  "count": 374283,
  "sum": "NaN",
  "sum_of_squares": "NaN",
  "mean": "NaN",
  "min": "NaN",
  "max": "NaN",
  "variance": "NaN",
  "std_deviation": "NaN",
  "built_query": "<TRUNCATED>",
  "cardinality": 10
Query the stats endpoint and use the count. The count is the sum of all userIds and the cardinality is the amount of unique userIds.
Greetings,
Philipp
So the 403 is because I didn’t filter by stream. Any thoughts on getting a “grand total” would be appreciated! Thanks again.
Edit: replies crossed in the mail :slight_smile: trying the stats query now.
I was a little quicker than your second response :wink: :smiley:
Yep, tried your suggestion & it works great, thanks!!
You’re welcome :slight_smile:
I’m happy that I was able to help :slight_smile:
