Could not load field
I have the error message: loading field information failed with status : Cannot GET htp://ip:9000/api/system/fields(500) . thank you for helping me. I looked on the forums but the impossible to find my error; configuration files are OK
Elasticsearch running
MongoDB running
Graylog-server running
server.conf :
Rest_listen_uri : http://ip:9000/api/
Web_listen_uri : http://ip:9000/
elasticsearch.yml :
cluster.name : graylog
dear ku
i’m sorry but with the lack of information I would just say - their is something wrong in the communication between Graylog and Elasticsearch.
Please provide:
  • Graylog Configuration
  • Elasticsearch Configuration
  • Graylog Logfiles
  • Elasticsearch Logfiles
  • action you have done
  • complete error message
  • Version of Graylog
  • Version of Elasticsearch
Graylog v2.4.3
ElasticSearch v5.6
Graylog Configuration :
Elasticsearch :
Error message :
Graylog Logfiles :
Elasticsearch Logfiles : no logs
Action : i just install graylog with documentation in graylog website. : http://docs.graylog.org/en/2.4/pages/installation/os/ubuntu.html
hej ku,
you would have made all persons live easier that want to help you if you would have just copy&paste the files as code blocks into the forum - just to have it said.
The last picture shows me that you did not have any Elasticsearch host configured - so Graylog is using the default (http://127.0.0.1:9200) if that does not match your setup, you do not have any Elasticsearch running so Graylog is not able to store and display any messages.
