Why didn’t it work? What was the output? What exactly did you add to the /etc/apt/sources.list.d/elasticsearch-2.x.list file?
What’s the output of these commands?
That’s a bad idea because it will create several directories and files with the wrong system user (root) and the elasticsearch system user won’t be able to access these directories and files.
Also, what’s the output of dpkg -l elasticsearch on that system?
This is how the output looks like on a healthy system:
$ dpkg -l elasticsearch
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii elasticsearch 2.4.4 all Elasticsearch is a distributed RESTful search engine built for the cloud. Reference documentation can be found at https://www.elastic.co/guide/en/elasticsearch/reference/current/index.html and the 'Elasticsearch: The Definitive Guide' book can be found at https://www.elastic.co/guide/en/elasticsearch/guide/current/index.html
I’m sorry to say that, but this is also taking too long to solve this and it’s obviously a problem with your Elasticsearch installation.
Please purge (uninstall and remove all data of) Elasticsearch from your system and follow the step-by-step guide at http://docs.graylog.org/en/2.2/pages/installation/os/ubuntu.html. It has been tested multiple times on a fresh installation of Ubuntu Linux and it is working.
Kindly please find my tail -f /var/log/graylog-server/server.log
file i am unable to get the logs in graylog
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [graylog.jar:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [graylog.jar:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [graylog.jar:?]
at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:384) [graylog.jar:?]
at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:224) [graylog.jar:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_131]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_131]
2017-06-05T11:46:31.114+05:30 ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
org.elasticsearch.cluster.block.ClusterBlockException: blocked by: [SERVICE_UNAVAILABLE/1/state not recovered / initialized];
at org.elasticsearch.cluster.block.ClusterBlocks.globalBlockedException(ClusterBlocks.java:158) ~[graylog.jar:?]
at org.elasticsearch.cluster.block.ClusterBlocks.globalBlockedRaiseException(ClusterBlocks.java:144) ~[graylog.jar:?]
at org.elasticsearch.action.search.AbstractSearchAsyncAction.(AbstractSearchAsyncAction.java:94) ~[graylog.jar:?]
at org.elasticsearch.action.search.SearchQueryThenFetchAsyncAction.(SearchQueryThenFetchAsyncAction.java:53) ~[graylog.jar:?]
at org.elasticsearch.action.search.TransportSearchAction.doExecute(TransportSearchAction.java:93) ~[graylog.jar:?]
at org.elasticsearch.action.search.TransportSearchAction.doExecute(TransportSearchAction.java:47) ~[graylog.jar:?]
at org.elasticsearch.action.support.TransportAction.doExecute(TransportAction.java:149) ~[graylog.jar:?]
at org.elasticsearch.action.support.TransportAction.execute(TransportAction.java:137) ~[graylog.jar:?]
at org.elasticsearch.action.support.TransportAction.execute(TransportAction.java:85) ~[graylog.jar:?]
at org.elasticsearch.client.node.NodeClient.doExecute(NodeClient.java:58) ~[graylog.jar:?]
at org.elasticsearch.client.support.AbstractClient.execute(AbstractClient.java:359) ~[graylog.jar:?]
at org.elasticsearch.client.FilterClient.doExecute(FilterClient.java:52) ~[graylog.jar:?]
at org.graylog2.indexer.elasticsearch.GlobalTimeoutClient.doExecute(GlobalTimeoutClient.java:58) ~[graylog.jar:?]
at org.elasticsearch.client.support.AbstractClient.execute(AbstractClient.java:348) ~[graylog.jar:?]
at org.elasticsearch.client.support.AbstractClient.search(AbstractClient.java:577) ~[graylog.jar:?]
at org.graylog2.indexer.elasticsearch.GlobalTimeoutClient.search(GlobalTimeoutClient.java:64) ~[graylog.jar:?]
at org.graylog2.indexer.searches.Searches.search(Searches.java:264) ~[graylog.jar:?]
at org.graylog2.rest.resources.search.RelativeSearchResource.searchRelative(RelativeSearchResource.java:113) ~[graylog.jar:?]
at sun.reflect.GeneratedMethodAccessor78.invoke(Unknown Source) ~[?:?]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_131]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_131]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$TypeOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:205) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [graylog.jar:?]
2017-06-05T11:46:35.683+05:30 ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
2017-06-05T11:46:37.576+05:30 INFO [IndexRetentionThread] Elasticsearch cluster not available, skipping index retention checks.
2017-06-05T11:46:40.704+05:30 ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
2017-06-05T11:46:41.344+05:30 WARN [V20161130141500_DefaultStreamRecalcIndexRanges] Interrupted or timed out waiting for Elasticsearch cluster, checking again.
2017-06-05T11:46:41.399+05:30 INFO [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2017-06-05T11:46:45.683+05:30 ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
2017-06-05T11:46:50.671+05:30 ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
2017-06-05T11:46:55.991+05:30 ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
