Unable to get messages in graylog web GUI
I have successfully configured graylog server. and unable to get the messages in graylog web GUI. I am getting error as
"Could not execute search
There was an error executing your search. Please check your Graylog server logs for more information.
Error Message:
blocked by: [SERVICE_UNAVAILABLE/1/state not recovered / initialized];: cannot GET http://192.168.2.147:12900/search/universal/relative?query=gl2_source_input%3A5af29f7d91fbb43a01dca396&range=28800&limit=150&sort=timestamp%3Adesc (500)
Search status code:
500"
and in client machine, i have done rsyslog configuration too. I.e in client machine, i have done the following things.
  1. Opened #vi /etc/rsyslog.d/90-graylog2.conf
$template GRAYLOGRFC5424,"%protocol-version% %timestamp:::date-rfc3339% %HOSTNAME% %app-name% %procid% %msg%\n"
*.* @<GraylogServerIP>:5140;GRAYLOGRFC5424
  1. opened #vi /etc/rsyslog.conf
                    $ModLoad imudp
                    $UDPServerRun 514
                    $ModLoad imtcp
                    $InputTCPServerRun 514
                    *.* @ <graylogServerIP>:514
and then restarted rsyslog service.
Now getting error as said above and unable to get messages. Please suggest me if i went wrong.
What’s in the logs of your Graylog and Elasticsearch nodes?
http://docs.graylog.org/en/2.4/pages/configuration/file_location.html
Please also refer to the Syslog configuration guide for Graylog for information about setting up rsyslog:
2018-05-09T12:34:24.784+05:30 INFO [CmdLineTool] Loaded plugin: Elastic Beats Input 2.2.3 [org.graylog.plugins.beats.BeatsInputPlugin]
2018-05-09T12:34:24.785+05:30 INFO [CmdLineTool] Loaded plugin: Collector 2.2.3 [org.graylog.plugins.collector.CollectorPlugin]
2018-05-09T12:34:24.786+05:30 INFO [CmdLineTool] Loaded plugin: Enterprise Integration Plugin 2.2.3 [org.graylog.plugins.enterprise_integration.EnterpriseIntegrationPlugin]
2018-05-09T12:34:24.786+05:30 INFO [CmdLineTool] Loaded plugin: MapWidgetPlugin 2.2.3 [org.graylog.plugins.map.MapWidgetPlugin]
2018-05-09T12:34:24.792+05:30 INFO [CmdLineTool] Loaded plugin: Pipeline Processor Plugin 2.2.3 [org.graylog.plugins.pipelineprocessor.ProcessorPlugin]
2018-05-09T12:34:24.792+05:30 INFO [CmdLineTool] Loaded plugin: Anonymous Usage Statistics 2.2.3 [org.graylog.plugins.usagestatistics.UsageStatsPlugin]
2018-05-09T12:34:25.098+05:30 INFO [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=rpm
2018-05-09T12:34:25.283+05:30 INFO [Version] HV000001: Hibernate Validator null
2018-05-09T12:34:26.963+05:30 INFO [InputBufferImpl] Message journal is enabled.
2018-05-09T12:34:27.021+05:30 INFO [NodeId] Node ID: 7eb22e66-e7b8-4427-abf9-6ecff00d5964
2018-05-09T12:34:27.162+05:30 INFO [LogManager] Loading logs.
2018-05-09T12:34:27.166+05:30 INFO [LogManager] Logs loading complete.
2018-05-09T12:34:27.232+05:30 INFO [LogManager] Created log for partition [messagejournal,0] in /var/lib/graylog-server/journal with properties {file.delete.delay.ms -> 60000, compact -> false, max.message.bytes -> 104857600, min.insync.replicas -> 1, segment.jitter.ms -> 0, index.interval.bytes -> 4096, min.cleanable.dirty.ratio -> 0.5, unclean.leader.election.enable -> true, retention.bytes -> 5368709120, delete.retention.ms -> 86400000, flush.ms -> 60000, segment.bytes -> 104857600, segment.ms -> 3600000, retention.ms -> 43200000, flush.messages -> 1000000, segment.index.bytes -> 1048576}.
2018-05-09T12:34:27.232+05:30 INFO [KafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2018-05-09T12:34:27.243+05:30 INFO [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy , running 2 parallel message handlers.
2018-05-09T12:34:27.255+05:30 INFO [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout=‘30000 ms’, maxWaitQueueSize=5000}
2018-05-09T12:34:27.291+05:30 INFO [cluster] No server chosen by ReadPreferenceServerSelector{readPreference=primary} from cluster description ClusterDescription{type=UNKNOWN, connectionMode=SINGLE, serverDescriptions=[ServerDescription{address=localhost:27017, type=UNKNOWN, state=CONNECTING}]}. Waiting for 30000 ms before timing out
2018-05-09T12:34:27.662+05:30 INFO [connection] Opened connection [connectionId{localValue:1, serverValue:1}] to localhost:27017
2018-05-09T12:34:27.664+05:30 INFO [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[3, 2, 20]}, minWireVersion=0, maxWireVersion=4, maxDocumentSize=16777216, roundTripTimeNanos=664420}
2018-05-09T12:34:27.688+05:30 INFO [connection] Opened connection [connectionId{localValue:2, serverValue:2}] to localhost:27017
2018-05-09T12:34:28.332+05:30 INFO [node] [graylog-7eb22e66-e7b8-4427-abf9-6ecff00d5964] version[2.4.4], pid[14849], build[fcbb46d/2017-01-03T11:33:16Z]
2018-05-09T12:34:28.332+05:30 INFO [node] [graylog-7eb22e66-e7b8-4427-abf9-6ecff00d5964] initializing …
2018-05-09T12:34:28.343+05:30 INFO [plugins] [graylog-7eb22e66-e7b8-4427-abf9-6ecff00d5964] modules [], plugins [graylog-monitor], sites []
2018-05-09T12:34:45.725+05:30 INFO [node] [graylog-7eb22e66-e7b8-4427-abf9-6ecff00d5964] initialized
2018-05-09T12:34:46.107+05:30 INFO [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy .
2018-05-09T12:34:48.709+05:30 INFO [RulesEngineProvider] No static rules file loaded.
2018-05-09T12:34:49.070+05:30 WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
Below are elastic search Logs
[2018-05-09 12:30:00,190][INFO ][node ] [Elathan] version[2.4.6], pid[14543], build[5376dca/2017-07-18T12:17:44Z]
[2018-05-09 12:30:00,191][INFO ][node ] [Elathan] initializing …
[2018-05-09 12:30:00,465][INFO ][plugins ] [Elathan] modules [reindex, lang-expression, lang-groovy], plugins [], sites []
[2018-05-09 12:30:00,526][INFO ][env ] [Elathan] using [1] data paths, mounts [[/ (rootfs)]], net usable_space [42.5gb], net total_space [46.9gb], spins? [unknown], types [rootfs]
[2018-05-09 12:30:00,526][INFO ][env ] [Elathan] heap size [990.7mb], compressed ordinary object pointers [true]
[2018-05-09 12:30:01,544][INFO ][node ] [Elathan] initialized
[2018-05-09 12:30:01,546][INFO ][node ] [Elathan] starting …
[2018-05-09 12:30:01,628][INFO ][transport ] [Elathan] publish_address {127.0.0.1:9300}, bound_addresses {[::1]:9300}, {127.0.0.1:9300}
[2018-05-09 12:30:01,633][INFO ][discovery ] [Elathan] graylog/Fs4GZz1SQhOErFTU_0z2-A
[2018-05-09 12:30:04,656][INFO ][cluster.service ] [Elathan] new_master {Elathan}{Fs4GZz1SQhOErFTU_0z2-A}{127.0.0.1}{127.0.0.1:9300}, reason: zen-disco-join(elected_as_master, [0] joins received)
[2018-05-09 12:30:04,664][INFO ][http ] [Elathan] publish_address {127.0.0.1:9200}, bound_addresses {[::1]:9200}, {127.0.0.1:9200}
[2018-05-09 12:30:04,664][INFO ][node ] [Elathan] started
[2018-05-09 12:30:04,678][INFO ][gateway ] [Elathan] recovered [0] indices into cluster_state
[2018-05-09 12:58:57,437][INFO ][node ] [Elathan] stopping …
[2018-05-09 12:59:00,046][INFO ][node ] [Elathan] stopped
[2018-05-09 12:59:00,047][INFO ][node ] [Elathan] closing …
[2018-05-09 12:59:01,327][INFO ][node ] [Elathan] closed
[2018-05-09 12:59:04,181][INFO ][node ] [Centennial] version[2.4.6], pid[15602], build[5376dca/2017-07-18T12:17:44Z]
[2018-05-09 12:59:04,181][INFO ][node ] [Centennial] initializing …
[2018-05-09 12:59:05,253][INFO ][plugins ] [Centennial] modules [reindex, lang-expression, lang-groovy], plugins [], sites []
[2018-05-09 12:59:05,362][INFO ][env ] [Centennial] using [1] data paths, mounts [[/ (rootfs)]], net usable_space [42.3gb], net total_space [46.9gb], spins? [unknown], types [rootfs]
[2018-05-09 12:59:05,363][INFO ][env ] [Centennial] heap size [990.7mb], compressed ordinary object pointers [true]
[2018-05-09 12:59:20,611][INFO ][node ] [Centennial] initialized
[2018-05-09 12:59:20,618][INFO ][node ] [Centennial] starting …
[2018-05-09 12:59:20,953][INFO ][transport ] [Centennial] publish_address {127.0.0.1:9300}, bound_addresses {[::1]:9300}, {127.0.0.1:9300}
[2018-05-09 12:59:21,004][INFO ][discovery ] [Centennial] graylog/lT0si95HQ7yVXoWrbXfXGA
[2018-05-09 12:59:24,048][INFO ][cluster.service ] [Centennial] new_master {Centennial}{lT0si95HQ7yVXoWrbXfXGA}{127.0.0.1}{127.0.0.1:9300}, reason: zen-disco-join(elected_as_master, [0] joins received)
[2018-05-09 12:59:24,059][INFO ][http ] [Centennial] publish_address {127.0.0.1:9200}, bound_addresses {[::1]:9200}, {127.0.0.1:9200}
[2018-05-09 12:59:24,059][INFO ][node ] [Centennial] started
[2018-05-09 12:59:24,082][INFO ][gateway ] [Centennial] recovered [0] indices into cluster_state
[2018-05-09 14:30:56,540][INFO ][node ] [Centennial] stopping …
[2018-05-09 14:30:59,875][INFO ][node ] [Centennial] stopped
[2018-05-09 14:30:59,875][INFO ][node ] [Centennial] closing …
[2018-05-09 14:31:00,368][INFO ][node ] [Centennial] closed
[2018-05-09 14:31:37,930][INFO ][node ] [Capricorn] version[2.4.6], pid[1147], build[5376dca/2017-07-18T12:17:44Z]
Are these the complete logs of Graylog and Elasticsearch?
Unless there are more messages in the Elasticsearch logs, it looks like the ES node isn’t running.
Those are all Logs. seems issue is with elastic search cluster. it is still in “updating” status in the graylog web GUI.
