is it possible to copy a stream using a stream rule like this:
Field: streams
Type: contain
Value: 57f4dd19055ef703b32889b1
I think this was possible in Version before 2.4.0.
In Addition to another rule like Level < 4 it would be possible to tailor a stream to certain levels (severities).
thank you very much.
But since 2.4.0 it looks like some rules in Graylog does not work anymore. The rules worked before in Graylog 2.3.
Example:
rule "drop_level7_netscaler_rule"
to_long($message.level) > 5
drop_message();
If I run the Simulator I get the result, that a (random) message would be dropped. But in reality never ever a message gets dropped.
now I see:
Depending on what “Message Input” i choose (RAW /Plaintext UDP or Syslog UDP) , I get “dropped” or not “dropped”.
But how can I change the “Message Input Type” on that stream. Or do I have to modify the underlying input?
I’m sorry, but that’s simply not enough information to give a reliable answer.
Maybe start by describing your setup and sharing the complete configuration of the relevant components (such as inputs, extractors, pipeline rules, etc.).
