In my Rest Access file there are stream OID’s, to display them on a Widget I needed to created a lookup table and Attached it to a pipeline.
Example:
Acquire the OID’s from MongoDb:
> use graylog
switched to db graylog
> db.streams.find({},{"title":1,"ObjectId":1});
{ "_id" : ObjectId("000000000000000000000001"), "title" : "All messages" }
{ "_id" : ObjectId("5a502736ffe8b10359166cf1"), "title" : "Firewall: Configuration Changed" }
{ "_id" : ObjectId("5a5027b7ffe8b10359166d83"), "title" : "Linux: Failed Authentication " }
{ "_id" : ObjectId("5a502865ffe8b10359166e4d"), "title" : "Switches: Failed Logon Attempts " }
{ "_id" : ObjectId("5a5028a4ffe8b10359166e9a"), "title" : "Windows: User Account Was Lockout" }
{ "_id" : ObjectId("5a5028f6ffe8b10359166efa"), "title" : "Windows: Audit Logs Are Cleared" }
{ "_id" : ObjectId("5a502a36ffe8b1035916706d"), "title" : "Windows: Service Failed Authentication Attempt " }
{ "_id" : ObjectId("5a502a80ffe8b103591670c3"), "title" : "Windows: User Credentials Failed logon Attempt" }
{ "_id" : ObjectId("5a502aebffe8b10359167141"), "title" : "Windows: User was Granted Administrator " }
{ "_id" : ObjectId("5a502b15ffe8b10359167174"), "title" : "Windows: User Account was Created " }
{ "_id" : ObjectId("5a502b71ffe8b103591671e0"), "title" : "Windows: Virtual Machine Faulty Disk " }
{ "_id" : ObjectId("5a6a7b9183d72e84ac7dd681"), "title" : "Windows: Server Name cannot be Resolved" }
{ "_id" : ObjectId("5ab06e1183d72e1a4a7ae1e0"), "title" : "Windows: Warning StorVSC " }
{ "_id" : ObjectId("5ade5c9c83d72e8a1240789f"), "title" : "Microsoft Antimalware " }
{ "_id" : ObjectId("5b9201d583d72e03a33047d6"), "title" : "Windows: User Successful Logon Local" }
{ "_id" : ObjectId("5b99ecd383d72e03a48fbfd1"), "title" : "Windows: Domain Controller DNS Error" }
{ "_id" : ObjectId("5b9b013d83d72e03a490eb82"), "title" : "Windows: DNS Server Errors" }
{ "_id" : ObjectId("5b9b016183d72e03a490ebaa"), "title" : "Windows: Domain Control DFS Replication" }
{ "_id" : ObjectId("5b9b017c83d72e03a490ebcb"), "title" : "Windows: Domain Controller Directory Service" }
{ "_id" : ObjectId("5b9c490d83d72e03a4924ee9"), "title" : "Windows: Domain Controller Time Sync Warning" }
Type "it" for more
Copy & Paste into lookup_table.csv.
[root@graylog graylog]# cat lookup_streams.cvs
"objectid","title"
"000000000000000000000001","All messages"
"5a502736ffe8b10359166cf1","Configuration Changed"
"5a5027b7ffe8b10359166d83","Failed Authentication"
"5a502865ffe8b10359166e4d","Switch Failed Logon Attempts"
"5a5028a4ffe8b10359166e9a","Windows User Account Was Lockout"
"5a5028f6ffe8b10359166efa","Windows Audit Logs Are Cleared"
"5a502a36ffe8b1035916706d","Windows Service Failed Authentication Attempt"
"5a502a80ffe8b103591670c3","Windows User Credentials Failed logon Attempt"
"5a502aebffe8b10359167141","Windows User was Granted Administrator"
"5a502b15ffe8b10359167174","Windows User Account was Created"
"5a502b71ffe8b103591671e0","Windows Virtual Machine Faulty Disk"
"5a6a7b9183d72e84ac7dd681","Windows Server Name cannot be Resolved"
"5ab06e1183d72e1a4a7ae1e0","Windows Warning StorVSC"
"5ade5c9c83d72e8a1240789f","Microsoft Antimalware"
"5b9201d583d72e03a33047d6","Windows User Successful Logon Local"
"5b99ecd383d72e03a48fbfd1","Windows Domain Controller DNS Error"
"5b9b013d83d72e03a490eb82","Windows DNS Server Errors"
I created a regex Extractor On Graylog Server INPUT to grab the OID and place it into a field called “stream_id”.
Using the Lookup_table in a pipeline.
rule"stream-lookup"
has_field("stream_id")
let streamoid = lookup_value("streamoid",$message.stream_id);
set_field("stream_name",streamoid);
Attach it to a stream that Graylog Server is using.
