Connection refused from rsyslog on any port or protocal
New install on test environment.
Can’t get rsyslogs into Graylog server no matter what port or protocol I configure the input for.
  • OS Information: Rocky 9.7
  • Package Version: 4.22c
    rsyslogd[892]: cannot connect to xxx.xxx.xxx.xxx2514 Connection refused
  • Everything is on the same sub-net.
    allow_override_date:
    true
  • bind_address:
    0.0.0.0
  • charset_name:
    UTF-8
  • expand_structured_data:
    false
  • force_rdns:
    false
  • number_worker_threads:
    8
  • override_source:
  • port:
    2514
  • recv_buffer_size:
    262144
  • store_full_message:
    true
  • timezone:
    America/Chicago
Firewall disabled on all systems.
enforcement set to Permissive on all systems.
Can ping everything from everything
TCPDump on Graylog server shows test server sending packets:
IP GrayLog.facsys-ntp > gtest.46742: Flags [R.], seq 0, ack 3805805647, win 0, length 0
ARP, Request who-has GrayLog tell gtest, length 28
ARP, Reply GrayLog is-at 52:54:00:11:5e:79 (oui Unknown), length 28
ARP, Request who-has gtest tell GrayLog, length 28
ARP, Reply gtest is-at 52:54:00:f6:f8:11 (oui Unknown), length 28
Why is nothing showing up in Graylog?
Input shows no data being recieved.
Are you sure the input it actually running. I say this because inputs now go into setup mode when created, and do not start until that is completed.
I rebuilt the input and received the following message:
Success
Input ‘Rsyslog UDP’ launched successfully
No data is showing as being received in the Graylog console.
On the client computer the following shows up in the system log:
gtest rsyslogd[892]: cannot connect to 172.xxx.xxxx.xxx:2514 (took 0.0 seconds): Connection refused
In the Graylog console for the Input, I see this:
Lifecycle state: Running
Is it possible locally to telnet to the port locally:
Possibilities should be visible with ‘$ netstat -an | grep 2514’
to see where and if the port is listening. It should be bound to the hosts IP adres and/or 0.0.0.0
udp6 0 0 :::2514 :::*
udp6 0 0 :::2514 :::sparkles:
We are not using IPv6 at all.
Really strange, your config is fine and there is nothing listening on ipv4.
here tcp4 is one 0.0.0.0:8514 listening, and all others active working on host-ip:8514 (rocky linux 8 / Graylog 6.1)
Is it possible to disable ipv6 completely, it is prone to these kind of issue’s sometimes.
