Rsyslog not sending logs
Hello everyone
Well it’ve been while i’m facing this probleme
I am trying hard to send logs from my ubuntu 14.04 ( using Rsyslog) (ip : 192.168.2.36)
To ===> my Graylog Server (192.168.2.37)
well this is the input configuration
and this my rsyslog conf
And when i run Wireshark with this filter i recive nothing
i’ll be thankfull if someone can help me !
thank u all ! :slight_smile:
N.B I am using Vmwar
Check the firewall rules and network configuration on the machine running Graylog.
Thank u for your answer i think the port 1514 is listning :confused:
and i just install this machine for test in vmwar i did not set up any firwall :confused:
Thank you again for your help Mr Jochen
What’s the output of the following commands on the machine running Graylog?
# sudo ufw status verbose
# sudo ufw app list
# sudo ufw show raw
Of the Server :
Of the Rsyslog machine :
IPV4 (raw):
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
pkts bytes target prot opt in out source destination
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
Chain OUTPUT (policy ACCEPT 0 packets, 0 bytes)
Chain PREROUTING (policy ACCEPT 525 packets, 47963 bytes)
Chain INPUT (policy ACCEPT 22 packets, 1878 bytes)
Chain OUTPUT (policy ACCEPT 3 packets, 354 bytes)
Chain POSTROUTING (policy ACCEPT 3 packets, 354 bytes)
Chain PREROUTING (policy ACCEPT 643 packets, 70086 bytes)
Chain INPUT (policy ACCEPT 140 packets, 24001 bytes)
Chain OUTPUT (policy ACCEPT 5 packets, 434 bytes)
Chain POSTROUTING (policy ACCEPT 7 packets, 748 bytes)
IPV6:
Chain PREROUTING (policy ACCEPT 62 packets, 4330 bytes)
Chain INPUT (policy ACCEPT 62 packets, 4330 bytes)
Chain OUTPUT (policy ACCEPT 4 packets, 498 bytes)
Chain POSTROUTING (policy ACCEPT 6 packets, 852 bytes)
here i used ncat to send msg over udp port 1514 and i found in elastic
echo “Testy” | ncat -u 192.168.2.36 1514
so i think it must be a rsyslog issue :confused:
Did you check rsyslog config so that it is actually running and loads your config file? Like rsyslogd -N1
Also: do you run SElinux? If you do, you need to make port 1541 a rsyslogd port with semanage, or else SElinux will not allow rsyslogd to send data there.
the output of
> rsyslogd -N1
rsyslogd: version 7.4.4, config validation run (level 1), master config /etc/rsyslog.conf
    rsyslogd: error: extra characters in config line ignored: '”<%PRI%>%PROTOCOL-VERSION% %TIMESTAMP:::date-rfc3339% %HOSTNAME% %APP-NAME% %PROCID% %MSGID% %STRUCTURED-DATA% %msg%\n”'
    rsyslogd:  Could not find template 'GRAYLOGRFC5424' - action disabled [try http://www.rsyslog.com/e/3003 ]
    rsyslogd: error during parsing file /etc/rsyslog.d/graylog_syslog.conf, on or before line 2: errors occured in file '/etc/rsyslog.d/graylog_syslog.conf' around line 2 [try http://www.rsyslog.com/e/2207 ]
    rsyslogd: error during parsing file /etc/rsyslog.d/graylog_syslog.conf, on or before line 3: errors occured in file '/etc/rsyslog.d/graylog_syslog.conf' around line 3 [try http://www.rsyslog.com/e/2207 ]
    rsyslogd: End of config validation run. Bye.
Maybe now i have somthing to solve ? thank u sire
amine-el-hijazi@ClientSys:~$ rsyslogd -N1
I think the probleme is fixed but still i don’t recive anything in the sever i have a very stupide how can i make sur that i m genereting logs that will be sent to the server , cauz i tried to restart services and other and nothing is working :frowning: so any idea ?
You can try running rsyslogd in debugging mode with -d.
Also make sure to read the syslog guide:
Well the probléme is solved !
thank u all very much
what helped me in this topic :
1 cheking my firwall rull
2 cheking the work of Rsyslog rsyslogd -N1
and i just find a stupide mistake in my configuration
And that is !
Thank u all for your help !
