Connection refuse port 9000 after upgrade
After upgrade on Graylog 3.0 -> 3.1, Graylog, Elasticsearch and Mongod are sucessfully stared but can’t access on the web interface, ss -tln port 9000 not listen:
listen-port
port 9000 is allowed on firewall (ufw)
And here is my config file:
# GRAYLOG CONFIGURATION FILE
# instances as master. The master will perform some periodical tasks that non-masters won't perform.
is_master = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting Graylog server from init scripts or similar.
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
password_secret = SvciTn0REg3xtFsm97TT9ARBfNbJVWgAM1NN6G8nhLn08NnfIQvvK8NFtEg9uS3QawCJ0k4LUAFLv64SnA1xThiZozQj7Tnj
root_username = admin
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
root_password_sha2 = a7cb3bd8c451adcee1cf035ee7ad63bece7db655be2d03399f3ce01f5a8cf711
# Default is empty
#root_email = ""
# Default is UTC
root_timezone = Europe/Skopje
#root_timezone = UTC
# Set the bin directory here (relative or absolute)
# This directory contains binaries that are used by the Graylog server.
# Default: bin
# Set the data directory here (relative or absolute)
# This directory is used to store Graylog server state.
# Default: data
# HTTP settings
#### HTTP bind address
# Default: 127.0.0.1:9000
#http_bind_address = 127.0.0.1:9000
http_bind_address = 192.168.254.211:9000
#### HTTP publish URI
# The URI will be published in the cluster discovery APIs, so that other Graylog nodes will be able to find and connect to this Graylog node.
# This configuration setting *must not* contain a wildcard address!
#MILAN
#http_publish_uri = http://0.0.0.0:9000/
#rest_listen_uri = http://0.0.0.0:9000/
#### External Graylog URI
# Default: $http_publish_uri
#MILAN
##http_external_uri = $http_publish_uri/
#### Enable CORS headers for HTTP interface
# This is necessary for JS-clients accessing the server directly.
# If these are disabled, modern browsers will not be able to retrieve resources from the server.
# This is enabled by default. Uncomment the next line to disable it.
http_enable_cors = true
#### Enable GZIP support for HTTP interface
# This compresses API responses and therefore helps to reduce
http_enable_gzip = true
http_max_header_size = 8192
# The size of the thread pool used exclusively for serving the HTTP interface.
http_thread_pool_size = 16
# HTTPS settings
# Default: false
http_enable_tls = false
# The password to unlock the private key used for securing the HTTP interface.
# requires authentication.
elasticsearch_hosts = http://0.0.0.0:9200
#MILAN
##elasticsearch_hosts = http://192.168.254.211:9200,http://admin:a7cb3bd8c451adcee1cf035ee7ad63bece7db655be2d03399f3ce01f5a8cf711@192.168.254.211:9200
# Maximum amount of time to wait for successfull connection to Elasticsearch HTTP port.
# Default: 10 Seconds
# Default: 60 seconds
# be tore down.
# Default: inf
# Default: 20
#elasticsearch_max_total_connections = 20
# elasticsearch server).
# Default: 2
#elasticsearch_max_total_connections_per_route = 2
# Maximum number of times Graylog will retry failed requests to Elasticsearch.
# Default: 2
#elasticsearch_max_retries = 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
# Default: false
#elasticsearch_discovery_enabled = true
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
#elasticsearch_discovery_filter = rack:42
# Default: 30s
# Default: false
# Graylog will use multiple indices to store documents in. You can configured the strategy it uses to determine
# when to rotate the currently active write index.
# It supports multiple rotation strategies:
#   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
#   - "size" per index, use elasticsearch_max_size_per_index below to configure
# valid values are "count", "size" and "time", default is "count"
#            This configuration setting is only used on the first start of Graylog. After that,
#            index related settings can be changed in the Graylog web interface on the 'System / Indices' page.
#            Also see http://docs.graylog.org/en/2.3/pages/configuration/index_model.html#index-set-configuration.
rotation_strategy = count
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
#no_retention = false
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
# Default: graylog-internal
# be enabled with care. See also: http://docs.graylog.org/en/2.1/pages/queries.html
allow_highlighting = false
# Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
# calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
# Default: 1m
#elasticsearch_request_timeout = 1m
# Default: 1h
# Default: 20
# Default: 1h
# Time interval for the job that runs index field type maintenance tasks like cleaning up stale entries. This doesn't
# need to run very often.
# Default: 1h
#index_field_type_periodical_interval = 1h
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
# The following settings (outputbuffer_processor_*) configure the thread pools backing each output buffer processor.
# See https://docs.oracle.com/javase/8/docs/api/java/util/concurrent/ThreadPoolExecutor.html for technical details
# When the number of threads is greater than the core (see outputbuffer_processor_threads_core_pool_size),
# this is the maximum time in milliseconds that excess idle threads will wait for new tasks before terminating.
# Default: 5000
# The number of threads to keep in the pool, even if they are idle, unless allowCoreThreadTimeOut is set
# Default: 3
# The maximum number of threads to allow in the pool
# Default: 30
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the disk based message journal.
# The directory which will be used to store the message journal. The directory must me exclusively used by Graylog and
# ATTENTION:
# disabled if not set.
# Length of the interval in seconds in which the alert conditions for all streams should be checked
# and alarms are being sent.
#alert_check_interval = 60
# messages end up.
#stale_master_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
mongodb_uri = mongodb://127.0.0.1/graylog
# '+'-signs in the username or password need to be replaced by '%2B'
#MILAN
mogodb_uri = mongodb://admin:a7cb3bd8c451adcee1cf035ee7ad63bece7db655be2d03399f3ce01f5a8cf711@127.0.0.1:27017/graylog
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog
#MILAN
#mongodb_uri = mongodb://grayloguser:a7cb3bd8c451adcee1cf035ee7ad63bece7db655be2d03399f3ce01f5a8cf711@127.0.0.1:27017,127.0.0.1:27018,127.0.0.1:27019/graylog
# http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Encryption settings
# ATTENTION:
#    Using SMTP with STARTTLS *and* SMTPS at the same time is *not* possible.
# Use SMTP with STARTTLS, see https://en.wikipedia.org/wiki/Opportunistic_TLS
# Use SMTP over SSL (SMTPS), see https://en.wikipedia.org/wiki/SMTPS
# This is deprecated on most SMTP services!
#transport_email_use_ssl = true
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
# ATTENTION: If you configure a proxy, make sure to also configure the "http_non_proxy_hosts" option so internal
#            HTTP connections with other nodes does not go through the proxy.
# Examples:
#   - http://proxy.example.com:8123
#   - http://username:password@proxy.example.com:8123
#http_proxy_uri =
# A list of hosts that should be reached directly, bypassing the configured proxy server.
# This is a list of patterns separated by ",". The patterns may start or end with a "*" for wildcards.
# Any host matching one of these patterns will be reached through a direct connection instead of through a proxy.
# Examples:
#   - localhost,127.0.0.1
#   - 10.0.*,*.example.com
#http_non_proxy_hosts =
#disable_index_optimization = true
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
# Disable the use of SIGAR for collecting system stats
#disable_sigar = false
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
# For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number
# of threads available for this. Increase it, if '/cluster/*' requests take long to complete.
# Should be http_thread_pool_size * average_cluster_size if you have a high number of concurrent users.
in the provided image I do not see anything listening on port 9000
Yes, why don’t listen ? Graylog is started, here is my log file for graylog :
Download from wetransfer
Do you have any suggestion ?
Thank you
check your log, I’ll not do it.
If someone can’t solve post here to help, but ok I solve the problem.
Thank you
let’s start from
systemctl status graylog-server.service
lsof -Pni :9000
Here is the status from Graylog is running
graylog-server.service - Graylog server
Loaded: loaded (/usr/lib/systemd/system/graylog-server.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/graylog-server.service.d
└─10-after_services.conf
Active: active (running) since Sun 2019-10-06 18:33:08 UTC; 25min ago
Docs: http://docs.graylog.org/
Main PID: 29485 (graylog-server)
Tasks: 50 (limit: 4915)
CGroup: /system.slice/graylog-server.service
├─29485 /bin/sh /usr/share/graylog-server/bin/graylog-server
└─29486 /usr/bin/java -Xms1g -Xmx1g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -jar -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=deb /usr/share/graylog-server/graylog.jar server -f /etc/graylog/server/server.conf -np
In Graylog log data give this problem:
cluster description not yet available waiting for 30000 ms before timing out
Thnak you
Check your mongodb logs, graylog is waiting for mongodb… did you updated mongodb version?
