I’m creating a Graylog cluster and i would like to authenticate to Graylog using AzureAD.
I’v already created an authentication on Graylog and an Application registrations on azureAD with the callback address…
The problem occurs when i try to login to graylog using my AzureAD account I got an error message and that message in logs:
2022-01-20T14:46:10.454+01:00 ERROR [OauthRequestUtils] Error attempting to fetch data from auth server. Got: 401 Unauthorized
2022-01-20T14:46:10.455+01:00 ERROR [OauthAuthServiceBackend] Unable to extract id and access tokens from JSON response
java.lang.NullPointerException: null
at org.graylog.plugins.security.authservice.backend.OauthAuthServiceBackend.fetchTokensFromAuthServer(OauthAuthServiceBackend.java:252) ~[?:?]
at org.graylog.plugins.security.authservice.backend.OauthAuthServiceBackend.authenticate(OauthAuthServiceBackend.java:136) ~[?:?]
at org.graylog.plugins.security.authservice.backend.OauthAuthServiceBackend.authenticateAndProvision(OauthAuthServiceBackend.java:81) ~[?:?]
at org.graylog.security.authservice.AuthServiceAuthenticator.authenticate(AuthServiceAuthenticator.java:94) ~[graylog.jar:?]
at org.graylog.security.authservice.AuthServiceAuthenticator.authenticate(AuthServiceAuthenticator.java:50) ~[graylog.jar:?]
at org.graylog2.security.realm.BearerTokenRealm.doGetAuthenticationInfo(BearerTokenRealm.java:69) ~[graylog.jar:?]
at org.graylog2.security.realm.BearerTokenRealm.doGetAuthenticationInfo(BearerTokenRealm.java:60) ~[graylog.jar:?]
at org.apache.shiro.realm.AuthenticatingRealm.getAuthenticationInfo(AuthenticatingRealm.java:571) ~[graylog.jar:?]
at org.apache.shiro.authc.pam.ModularRealmAuthenticator.doMultiRealmAuthentication(ModularRealmAuthenticator.java:225) ~[graylog.jar:?]
at org.apache.shiro.authc.pam.ModularRealmAuthenticator.doAuthenticate(ModularRealmAuthenticator.java:275) ~[graylog.jar:?]
at org.apache.shiro.authc.AbstractAuthenticator.authenticate(AbstractAuthenticator.java:198) ~[graylog.jar:?]
at org.apache.shiro.mgt.AuthenticatingSecurityManager.authenticate(AuthenticatingSecurityManager.java:106) ~[graylog.jar:?]
at org.apache.shiro.mgt.DefaultSecurityManager.login(DefaultSecurityManager.java:275) ~[graylog.jar:?]
at org.apache.shiro.subject.support.DelegatingSubject.login(DelegatingSubject.java:260) ~[graylog.jar:?]
at org.graylog2.shared.security.SessionCreator.create(SessionCreator.java:82) ~[graylog.jar:?]
at org.graylog2.rest.resources.system.SessionsResource.newSession(SessionsResource.java:142) ~[graylog.jar:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory.lambda$static$0(ResourceMethodInvocationHandlerFactory.java:52) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:124) [graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:167) [graylog.jar:?]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$TypeOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:219) [graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:79) [graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:469) [graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:391) [graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:80) [graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime$1.run(ServerRuntime.java:255) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:248) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:244) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:292) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:274) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:244) [graylog.jar:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:265) [graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:234) [graylog.jar:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:680) [graylog.jar:?]
at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:356) [graylog.jar:?]
at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:200) [graylog.jar:?]
at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:180) [graylog.jar:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) [?:?]
at java.lang.Thread.run(Thread.java:829) [?:?]
2022-01-20T14:46:10.468+01:00 WARN [BearerTokenRealm] Failed to authenticate username <<token>> with backend <Azure_authentication/oidcXXXXXXXXXXXXXXXXXXXX>
2022-01-20T14:46:10.470+01:00 INFO [SessionCreator] Invalid credentials in session create request. Actor: "urn:graylog:node:XXXXXXXXXXXXXXXXXXXXXXXXX"
Graylog 4.2.5+59802bf on localhost (Debian 11.0.13 on Linux 5.10.0-9-amd64
I already tried to configure the token configuration on Azure but that didn’t help.
Could you help me to understand the messagei got int my logs.
Thank you!
