Connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond
time=“2020-10-31T09:22:09+05:30” level=error msg="[UpdateRegistration] Failed to report collector status to server: Put http://<SERVER_IP>:9000/api/sidecars/3e29e0e1-0115-45ed-9bbb-68ae13ddd8b2: dial tcp <SERVER_IP>:9000: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond."
is being reported reported in graylog web interface by the windows hyperv host.
I tried stoping and starting nxlog, graylog-sidecar and graylog-collector-sidecar services but now improvement.
2020-11-03 22:03:22.000 HYPER
time=“2020-11-03T16:55:42+05:30” level=info msg=“Stopping signal distributor”
time=“2020-11-03T19:36:34+05:30” level=error msg="[nxlog] Backend finished unexpectedly, sending restart signal"
time=“2020-11-03T19:37:10+05:30” level=info msg="[nxlog] Configuration change detected, rewriting configuration file."
2020-11-03 22:03:22.000 HYPERV
time=“2020-11-03T19:40:11+05:30” level=info msg="[nxlog] Got remote start command"
time=“2020-11-03T19:47:36+05:30” level=info msg=“Stopping signal distributor”
time=“2020-11-03T19:47:39+05:30” level=info msg=“Starting signal distributor”
time=“2020-11-03T19:47:49+05:30” level=info msg=“Adding process runner for: nxlog”
Please suggest. I checked the sidecar.yml file and configuration seems to be correct.
you might want to add some more context.
What Graylog version, what sidecar Version did you have?
