Complete novice needs help with setting up filters / query
Hi
I am a complete novice when it comes to Graylog. I have just been given access to a dashboard and I want to set up filters / queries.
I have an idea what to do but need help with the language / syntax.
I need to create many filters with machines that use - in their names.
The machines are in OU’s on AD based on model and the asset tags we use in college. These OU’s can contain upto 20 machies
Eg
HP840-78260
HP840-78278
When it add the names into a filter the second part of the names is red
HP840 then red - and red number.
I need to create a filter like hp840-78260 OR hp840-78278 OR etc…for upto the 20 devices.
If i can get an example then I can just copy the filter and edit the machine names.
I hope i have explained myself enough…
Many thanks
Neil
When you are executing a search, special characters have to be escaped so searching for HP840-78260 would be HP840\-78260
I think that is what you are looking for… ?
