I want to send the Deep Security Log to Graylog with TLS.
Does anyone do it ?
Best Regards,
Does anyone do it ?
Best Regards,
Which transport protocols does Deep Security support for exporting or streaming its logs?
Thank you for your reply.
Deep Security supports syslog over TCP.
In this case you can use a Syslog TCP or Raw/Plaintext TCP input in Graylog.
Both support encrypting the connection via TLS.
