I just upgraded to 2.4.6 and for the first time in ages ran a script I had been working on for detecting outages/etc in graylog. I used “localhost:12900/system/cluster/stats/mongo” to check to see if mongodb was working.
Anyway, now it appears I’m being asked to do HTTP Basic auth (that was mentioned in the release notes for 2.4.6) - but now it’s returning ““server_status”:null” whereas it used to return ““server_status”:available”
Was that intentional? It’s made the API not as useful
That is the problem. But what role is needed for that? The only references I can find imply the username that graylog uses has to have full admin perms for the entire mongodb server, surely it doesn’t need that?
