I’m using OSSEC to ship its events using syslog to the CEF plugin listening on UDP. In the graylog server log I’m seeing a lot of these of which I’m not sure what to make of:
2019-04-24T08:15:31.668Z WARN [MappedMessage] Could not transform CEF field [type] according to standard. Skipping.
java.lang.NumberFormatException: For input string: "1400 audit(1556093729.307:558793): avc: denied { signull } for"
at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65) ~[?:1.8.0_212]
at java.lang.Integer.parseInt(Integer.java:580) ~[?:1.8.0_212]
at java.lang.Integer.parseInt(Integer.java:615) ~[?:1.8.0_212]
at org.graylog.plugins.cef.parser.CEFMapping.convertInteger(CEFMapping.java:249) ~[graylog.jar:?]
at org.graylog.plugins.cef.parser.CEFMapping.convertType(CEFMapping.java:274) ~[graylog.jar:?]
at org.graylog.plugins.cef.parser.CEFMapping.convert(CEFMapping.java:314) ~[graylog.jar:?]
at org.graylog.plugins.cef.parser.MappedMessage.mapExtensions(MappedMessage.java:52) [graylog.jar:?]
at org.graylog.plugins.cef.parser.MappedMessage.<init>(MappedMessage.java:37) [graylog.jar:?]
at org.graylog.plugins.cef.codec.CEFCodec.decodeCEF(CEFCodec.java:128) [graylog.jar:?]
at org.graylog.plugins.cef.codec.CEFCodec.decode(CEFCodec.java:112) [graylog.jar:?]
at org.graylog2.shared.buffers.processors.DecodingProcessor.processMessage(DecodingProcessor.java:150) [graylog.jar:?]
at org.graylog2.shared.buffers.processors.DecodingProcessor.onEvent(DecodingProcessor.java:91) [graylog.jar:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:74) [graylog.jar:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:42) [graylog.jar:?]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_212]
java.lang.NumberFormatException: For input string: "1400 audit(1556093730.364:558794): avc: denied { name_connect } for"
