Can't acces to my interface web
I install graylog and i got this error on my log graylog
2018-06-26T15:57:07.566+02:00 ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
com.mongodb.MongoQueryException: Query failed with error code 11600 and error message 'interrupted at shutdown' on server localhost:27017
        at com.mongodb.operation.FindOperation$1.call(FindOperation.java:720) ~[graylog.jar:?]
        at com.mongodb.operation.FindOperation$1.call(FindOperation.java:709) ~[graylog.jar:?]
        at com.mongodb.operation.OperationHelper.withConnectionSource(OperationHelper.java:433) ~[graylog.jar:?]
        at com.mongodb.operation.OperationHelper.withConnection(OperationHelper.java:406) ~[graylog.jar:?]
        at com.mongodb.operation.FindOperation.execute(FindOperation.java:709) ~[graylog.jar:?]
        at com.mongodb.operation.FindOperation.execute(FindOperation.java:81) ~[graylog.jar:?]
        at com.mongodb.Mongo.execute(Mongo.java:810) ~[graylog.jar:?]
        at com.mongodb.Mongo$2.execute(Mongo.java:797) ~[graylog.jar:?]
        at com.mongodb.DBCursor.initializeCursor(DBCursor.java:871) ~[graylog.jar:?]
        at com.mongodb.DBCursor.hasNext(DBCursor.java:142) ~[graylog.jar:?]
        at com.mongodb.DBCursor.one(DBCursor.java:680) ~[graylog.jar:?]
        at com.mongodb.DBCollection.findOne(DBCollection.java:831) ~[graylog.jar:?]
        at com.mongodb.DBCollection.findOne(DBCollection.java:794) ~[graylog.jar:?]
        at com.mongodb.DBCollection.findOne(DBCollection.java:741) ~[graylog.jar:?]
        at org.graylog2.database.PersistedServiceImpl.findOne(PersistedServiceImpl.java:128) ~[graylog.jar:?]
        at org.graylog2.cluster.NodeServiceImpl.byNodeId(NodeServiceImpl.java:73) ~[graylog.jar:?]
        at org.graylog2.shared.rest.resources.ProxiedResource.lambda$createRemoteInterfaceProvider$4(ProxiedResource.java:107) ~[graylog.jar:?]
        at org.graylog2.shared.rest.resources.ProxiedResource.lambda$getForAllNodes$2(ProxiedResource.java:72) ~[graylog.jar:?]
        at java.util.stream.Collectors.lambda$toMap$58(Collectors.java:1321) ~[?:1.8.0_171]
        at java.util.stream.ReduceOps$3ReducingSink.accept(ReduceOps.java:169) ~[?:1.8.0_171]
        at java.util.HashMap$KeySpliterator.forEachRemaining(HashMap.java:1553) ~[?:1.8.0_171]
        at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481) ~[?:1.8.0_171]
        at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471) ~[?:1.8.0_171]
        at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:708) ~[?:1.8.0_171]
        at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:1.8.0_171]
        at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:499) ~[?:1.8.0_171]
        at org.graylog2.shared.rest.resources.ProxiedResource.getForAllNodes(ProxiedResource.java:72) ~[graylog.jar:?]
        at org.graylog2.shared.rest.resources.ProxiedResource.getForAllNodes(ProxiedResource.java:67) ~[graylog.jar:?]
        at org.graylog2.rest.resources.cluster.ClusterMetricsResource.multipleMetricsAllNodes(ClusterMetricsResource.java:74) ~[graylog.jar:?]
        at sun.reflect.GeneratedMethodAccessor34.invoke(Unknown Source) ~[?:?]
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_171]
        at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_171]
        at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[graylog.jar:?]
        at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[graylog.jar:?]
        at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[graylog.jar:?]
        at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$TypeOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:205) ~[graylog.jar:?]
        at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[graylog.jar:?]
        at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[graylog.jar:?]
        at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[graylog.jar:?]
        at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[graylog.jar:?]
        at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [graylog.jar:?]
        at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [graylog.jar:?]
        at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [graylog.jar:?]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [graylog.jar:?]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [graylog.jar:?]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [graylog.jar:?]
        at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [graylog.jar:?]
        at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [graylog.jar:?]
        at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [graylog.jar:?]
        at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:384) [graylog.jar:?]
        at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:224) [graylog.jar:?]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_171]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_171]
        at java.lang.Thread.run(Thread.java:748) [?:1.8.0_171]
it looks like your mongoDB is not running.
I do one systemctl status for see is running :
can you access your mongoDB with the configuration that is present in your Graylog server.conf?
Query failed with error code 11600 and error message ‘interrupted at shutdown’ on server localhost:27017
indicates that something is wrong with your mongodb and a quick search revealed that you might can repair that with mongod --repair (covered by the docs https://docs.mongodb.com/manual/tutorial/recover-data-following-unexpected-shutdown/ )
