Can not set TCP_NODELAY and Connection reset
While tracking down an apparent memory leak in graylog, I found a lot of these errors in the logs:
2025-03-31 09:13:24,752 WARN o.g.g.n.t.TCPNIOTransport [grizzly-nio-kernel(1) SelectorRunner] GRIZZLY0004: Can not set TCP_NODELAY to true
java.net.SocketException: Connection reset by peer
	at java.base/sun.nio.ch.Net.setIntOption0(Native Method) ~[?:?]
	at java.base/sun.nio.ch.Net.setSocketOption(Net.java:455) ~[?:?]
	at java.base/sun.nio.ch.Net.setSocketOption(Net.java:393) ~[?:?]
	at java.base/sun.nio.ch.SocketChannelImpl.setOption(SocketChannelImpl.java:280) ~[?:?]
	at java.base/sun.nio.ch.SocketAdaptor.setBooleanOption(SocketAdaptor.java:237) ~[?:?]
	at java.base/sun.nio.ch.SocketAdaptor.setTcpNoDelay(SocketAdaptor.java:273) ~[?:?]
	at org.glassfish.grizzly.nio.transport.TCPNIOTransport$DefaultChannelConfigurator.postConfigure(TCPNIOTransport.java:756) [graylog.jar:?]
	at org.glassfish.grizzly.nio.transport.TCPNIOServerConnection.configureAcceptedChannel(TCPNIOServerConnection.java:156) [graylog.jar:?]
	at org.glassfish.grizzly.nio.transport.TCPNIOServerConnection.onAccept(TCPNIOServerConnection.java:211) [graylog.jar:?]
	at org.glassfish.grizzly.nio.transport.TCPNIOTransport.fireIOEvent(TCPNIOTransport.java:485) [graylog.jar:?]
	at org.glassfish.grizzly.strategies.AbstractIOStrategy.fireIOEvent(AbstractIOStrategy.java:82) [graylog.jar:?]
	at org.glassfish.grizzly.strategies.SameThreadIOStrategy.executeIoEvent(SameThreadIOStrategy.java:69) [graylog.jar:?]
	at org.glassfish.grizzly.strategies.AbstractIOStrategy.executeIoEvent(AbstractIOStrategy.java:66) [graylog.jar:?]
	at org.glassfish.grizzly.nio.SelectorRunner.iterateKeyEvents(SelectorRunner.java:381) [graylog.jar:?]
	at org.glassfish.grizzly.nio.SelectorRunner.iterateKeys(SelectorRunner.java:353) [graylog.jar:?]
	at org.glassfish.grizzly.nio.SelectorRunner.doSelect(SelectorRunner.java:319) [graylog.jar:?]
	at org.glassfish.grizzly.nio.SelectorRunner.run(SelectorRunner.java:248) [graylog.jar:?]
	at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:535) [graylog.jar:?]
	at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.run(AbstractThreadPool.java:515) [graylog.jar:?]
	at java.base/java.lang.Thread.run(Thread.java:840) [?:?]
How can I track down which TCP connections are causing the errors?
I have three inputs enabled
  • syslog (UDP)
  • Filebeat (TCP)
  • Netflow (UDP)
Since it’s TCP errors, it’s either Filebeat or the connections to OpenSearch.
I’m not very concerned about not being able to set TCP_NODELAY (although I would like to silence the warnings), but connection reset by peer isn’t good.
  • OS Information:
FreeBSD 14.2-RELEASE
  • Package Version:
6.1.8
I’d like help to track down which connections are causing the errors, and a way to silence the TCP_NODELAY warnings (or convince me I need it enabled in the OS).
I found WARN o.g.g.n.t.TCPNIOTransport [grizzly-nio-kernel(1) SelectorRunner] GRIZZLY0004: Can not set TCP_NODELAY to true - #8 which shows a way to silence the errors, but I’m curious about two things:
  • Should I enable TCP NODELAY?
  • How can I debug which connections are affected?
