Hi
Created a stream named DMS - STREAM, can this stream takes data from two inputs because I need two inputs data into the single stream.
I am using Graylog Version - 2.4.6
Quick response will be appreciated.
Hi
Yes, that’s perfectly possible.
You just have to write stream rules matching the messages you want to route to that stream.
http://docs.graylog.org/en/2.4/pages/streams.html
Can you tell me how @jochen
Please elaborate on your use case and provide some examples.
In general, the stream routing happens way after the messages have been received and processed by extractors, so you can simply refer to the required fields in your stream rules.
