BUILD FAILURE with Failed to execute goal on project
HI guys ,
im trying to build graylog project i get below error
Failed to execute goal on project graylog-project: Could not resolve dependencies for project org.graylog:graylog-project:pom:2.3.0-rc.2-SNAPSHOT: Could not find artifact org.graylog.plugins:graylog-plugin-map-widget:jar:2.3.0-rc.2-SNAPSHOT -> [Help 1]
i’m totally confused please help
graylog-prohect/pom.xml
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0"
         xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
    <modelVersion>4.0.0</modelVersion>
    <groupId>org.graylog</groupId>
    <artifactId>graylog-project</artifactId>
    <version>2.3.0-rc.2-SNAPSHOT</version>
    <packaging>pom</packaging>
    <scm>
        <connection>scm:git:git@github.com:Graylog2/graylog-project.git</connection>
        <developerConnection>scm:git:git@github.com:Graylog2/graylog-project.git</developerConnection>
        <url>https://github.com/Graylog2/graylog-project</url>
        <tag>HEAD</tag>
    </scm>
    <modules>
        <module>runner</module>
        <module>../graylog-project-repos/graylog2-server</module>
        <module>../graylog-project-repos/graylog-plugin-map-widget</module>
    </modules>
    <properties>
        <project.reporting.outputEncoding>UTF-8</project.reporting.outputEncoding>
        <project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
        <maven.compiler.source>1.8</maven.compiler.source>
        <maven.compiler.target>1.8</maven.compiler.target>
        <maven.compiler.useIncrementalCompilation>false</maven.compiler.useIncrementalCompilation>
        <maven.build.timestamp.format>yyyyMMddHHmmss</maven.build.timestamp.format>
        <maven.source.skip>true</maven.source.skip>
        <maven.javadoc.skip>true</maven.javadoc.skip>
        <maven.install.skip>true</maven.install.skip>
        <maven.deploy.skip>true</maven.deploy.skip>
        <maven.site.skip>true</maven.site.skip>
        <!-- to work around filtering bug, which makes maven.build.timestamp inaccessible -->
        <build.timestamp>${maven.build.timestamp}</build.timestamp>
    </properties>
    <dependencies>
        <dependency>
            <groupId>org.graylog2</groupId>
            <artifactId>graylog2-server</artifactId>
        </dependency>
        <dependency>
            <groupId>org.graylog.plugins</groupId>
            <artifactId>graylog-plugin-map-widget</artifactId>
        </dependency>
    </dependencies>
    <build>
        <plugins>
            <plugin>
                <artifactId>maven-assembly-plugin</artifactId>
                <version>2.6</version>
                <configuration>
                    <attach>false</attach>
                    <appendAssemblyId>false</appendAssemblyId>
                    <ignoreMissingDescriptor>true</ignoreMissingDescriptor>
                    <finalName>graylog-${project.version}-${maven.build.timestamp}</finalName>
                    <descriptors>
                        <descriptor>src/main/assembly/server-tarball.xml</descriptor>
                    </descriptors>
                </configuration>
            </plugin>
            <plugin>
                <groupId>com.mycila</groupId>
                <artifactId>license-maven-plugin</artifactId>
                <version>2.11</version>
                <configuration>
                    <skip>true</skip>
                </configuration>
                <executions>
                    <execution>
                        <goals>
                            <goal>check</goal>
                        </goals>
                    </execution>
                </executions>
            </plugin>
        </plugins>
    </build>
    <profiles>
        <profile>
            <id>release</id>
            <build>
                <plugins>
                    <plugin>
                        <groupId>org.apache.maven.plugins</groupId>
                        <configuration>
                            <finalName>graylog-${project.version}</finalName>
                        </configuration>
                  </plugin>
                </plugins>
            </build>
        </profile>
    </profiles>
</project>
graylog-project-repos/graylog-plugin-map-widget/pom.xml
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
    <prerequisites>
        <maven>3.1</maven>
    </prerequisites>
    <parent>
        <artifactId>graylog-plugin-web-parent</artifactId>
        <relativePath>../graylog2-server/graylog-plugin-parent/graylog-plugin-web-parent</relativePath>
    </parent>
    <packaging>jar</packaging>
    <name>${project.artifactId}</name>
    <description>Graylog Map Widget and GeoIP plugin.</description>
    <url>https://www.graylog.org</url>
    <developers>
        <developer>
            <name>Edmundo Alvarez</name>
            <email>edmundo@graylog.com</email>
        </developer>
    </developers>
    <scm>
        <connection>scm:git:git@github.com:Graylog2/graylog-plugin-map-widget.git</connection>
        <developerConnection>scm:git:git@github.com:Graylog2/graylog-plugin-map-widget.git</developerConnection>
        <url>https://github.com/Graylog2/graylog-plugin-map-widget</url>
        <tag>HEAD</tag>
    </scm>
    <distributionManagement>
        <snapshotRepository>
            <id>sonatype-nexus-snapshots</id>
            <name>Sonatype Nexus Snapshots</name>
            <url>https://oss.sonatype.org/content/repositories/snapshots</url>
        </snapshotRepository>
        <repository>
            <id>sonatype-nexus-staging</id>
            <name>Nexus Release Repository</name>
            <url>https://oss.sonatype.org/service/local/staging/deploy/maven2/</url>
        </repository>
    </distributionManagement>
    <repositories>
        <!-- to make our snapshot releases work with Travis et al -->
        <repository>
            <releases>
                <enabled>false</enabled>
            </releases>
            <snapshots>
                <enabled>true</enabled>
            </snapshots>
        </repository>
        <repository>
            <id>sonatype-nexus-releases</id>
            <name>Sonatype Nexus Releases</name>
            <url>https://oss.sonatype.org/content/repositories/releases</url>
            <releases>
            </releases>
            <snapshots>
            </snapshots>
        </repository>
    </repositories>
    <properties>
        <graylog.version>2.3.0-rc.2-SNAPSHOT</graylog.version>
    </properties>
    <dependencies>
        <dependency>
            <version>${graylog.version}</version>
            <scope>provided</scope>
        </dependency>
        <dependency>
            <groupId>org.graylog.autovalue</groupId>
            <artifactId>auto-value-javabean</artifactId>
        </dependency>
        <dependency>
            <groupId>com.maxmind.geoip2</groupId>
            <artifactId>geoip2</artifactId>
            <version>2.8.1</version>
        </dependency>
        <dependency>
            <groupId>org.testng</groupId>
            <artifactId>testng</artifactId>
            <version>6.9.10</version>
            <scope>test</scope>
        </dependency>
        <dependency>
            <groupId>com.google.auto.value</groupId>
            <artifactId>auto-value</artifactId>
            <version>${auto-value.version}</version>
        </dependency>
    </dependencies>
    <build>
        <resources>
            <resource>
                <directory>build</directory>
            </resource>
            <resource>
                <directory>src/main/resources</directory>
                <filtering>true</filtering>
            </resource>
        </resources>
        <plugins>
            <plugin>
                <configuration>
                    <skipAssembly>true</skipAssembly>
                </configuration>
            </plugin>
            <plugin>
                <artifactId>maven-jar-plugin</artifactId>
                <configuration>
                    <archive>
                        <manifestEntries>
                            <Graylog-Plugin-Properties-Path>${project.groupId}.${project.artifactId}</Graylog-Plugin-Properties-Path>
                        </manifestEntries>
                    </archive>
                </configuration>
            </plugin>
            <plugin>
                <configuration>
                    <header>com/mycila/maven/plugin/license/templates/GPL-3.txt</header>
                    <properties>
                        <owner>${project.organization.name}</owner>
                        <project.name>Graylog</project.name>
                    </properties>
                    <includes>
                        <include>**/src/main/java/**</include>
                        <include>**/src/test/java/**</include>
                    </includes>
                </configuration>
                <executions>
                    <execution>
                        <goals>
                            <goal>check</goal>
                        </goals>
                    </execution>
                </executions>
            </plugin>
            <plugin>
                <artifactId>maven-shade-plugin</artifactId>
                <version>2.4.3</version>
                <configuration>
                    <createDependencyReducedPom>false</createDependencyReducedPom>
                    <minimizeJar>false</minimizeJar>
                </configuration>
                <executions>
                    <execution>
                        <phase>package</phase>
                        <goals>
                            <goal>shade</goal>
                        </goals>
                        <configuration>
                            <transformers>
                                <transformer implementation="org.apache.maven.plugins.shade.resource.ServicesResourceTransformer" />
                            </transformers>
                        </configuration>
                    </execution>
                </executions>
            </plugin>
            <plugin>
                <artifactId>maven-release-plugin</artifactId>
                <configuration>
                    <autoVersionSubmodules>true</autoVersionSubmodules>
                    <mavenExecutorId>forked-path</mavenExecutorId>
                    <tagNameFormat>@{project.version}</tagNameFormat>
                    <preparationGoals>clean test</preparationGoals>
                    <goals>package</goals>
                </configuration>
            </plugin>
        </plugins>
    </build>
</project>
Please describe each step that you’ve taken (i. e. which commands you’ve executed and what their output was).
I did a it mvn compile it was success
mvn install -DskipTests=true -Dmaven.javadoc.skip=true -B -V was also successful
# mvn -B -Dmaven.test.skip=true -Dskip.web.build=true assembly:single  failed with below error
In which directories exactly did you execute these commands?
What was their complete and unabbreviated output?
@jochen thanks for your help i missfired the command as
instead of
mvn package -B -Dmaven.test.skip=true -Dskip.web.build=true assembly:single
