ortizleo
(Leonardo Ortiz)
September 11, 2018, 2:29am
1
Hello.
What is the best pratices for index and streams usage?
My general questions is:
Should I have one index per server/service?
One stream for server, service or Event?
Use stream rules or pipelines? Why?
Can you share you experiences and stream, index and pipelines setup?
jan
(Jan Doberstein)
September 11, 2018, 7:05am
2
The flexibility is what it makes complicated. Maybe our reworked getting started guide can help you a little: http://docs.graylog.org/en/2.4/pages/getting_started.html
But the way you work and configure your setup is primary based on your usecase. You do not have “one way” to solve.
ortizleo
(Leonardo Ortiz)
September 11, 2018, 2:01pm
3
Fine, will read it a bit more the getting started
About pipeline x stream rules, its OK use stream rule instead pipeline? I read some users talking that pipeline is more recommended.
jan
(Jan Doberstein)
September 11, 2018, 3:03pm
4
it depends how you have your processing order ( System > Configuration
) if that makes sense or not.
You can’t use stream rules you create in processing pipelines when the order of processing have the pipelines after the message filter chain - but you should have the processing pipelines after the message filter chain to have the streamrules already finished.
system
(system)
Closed
September 25, 2018, 3:03pm
5
