Hey Guys -
I’m new to GrayLog and even though considering using it for work, am trying it out at home first. I’ve already added the appliance, am sending Windows Event logs using nxlog, and seem good to go; but have a question about how to configure what I’m wanting to do.
I have a few different apps that I host on my home PC and I’d like to have the log files from all of them go into Gray log so they’ll be in a central location. The thing is, most of them don’t offer anything close to syslog or other forwarding capabilities - they just write to log files.
My Question
So given the above, would be the best way to have these feed into GrayLog? I don’t know if I need to use nxlog agent, a Marketplace plugin / content pack, manual configuration, a combination of them, or something different altogether. Below are some examples of them and their formatting. All are running on Windows
App #1
- Writes to a .log file which is rolled over each time it gets to 1mb (about every 2 days)
- Examples of the log file formatting
06-Apr-2017 01:58:16 - INFO :: Thread-21 : Parsing results from
06-Apr-2017 01:58:18 - INFO :: Thread-21 : No results found from
06-Apr-2017 01:58:18 - INFO :: Thread-21 : Parsing results from
App #2
- Writes to a .txt file which is rolled over when it gets to 1mb
17-4-6 10:15:15.6|Error|XbmcMetadata|Unable to process episode image for file
[v2.0.0.4688] System.InvalidOperationException: Sequence contains no elements
at System.Linq.Enumerable.First[TSource](IEnumerable`1 source)
at NzbDrone.Core.Extras.Metadata.Consumers.Xbmc.XbmcMetadata.EpisodeImages(Series series, EpisodeFile episodeFile) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Extras\Metadata\Consumers\Xbmc\XbmcMetadata.cs:line 345
17-4-6 10:15:16.1|Info|RefreshEpisodeService|Starting episode info refresh
17-4-6 10:15:16.2|Info|RefreshEpisodeService|Finished episode refresh
17-4-6 10:15:16.2|Info|DiskScanService|Scanning disk
Log file also seems to include some HTML code
App #3
Simple - Apache 2.4 for Windows
App #4
- Writes to a .log file which is rolled over when it gets to 5mb
2017-04-02 19:48:28,349::INFO::[postproc:87] Saving postproc queue
2017-04-02 19:48:28,351::INFO::[init:971] Saving data for postproc2
2017-04-02 19:48:28,351::INFO::[downloader:300] Post-processing finished
App #5
- Writes to a .log file which is rolled over when it gets to 500kb
- Examples of the log file formatting (This one seems to have non-standard characters in it)
03-21 21:37:51 ERROR e[31mFailed encoding stuff to log “Cant find it in database. Are you sure this it exists?”: not all arguments converted during string formattinge[0m
03-21 21:37:51 ERROR e[31m[e.providers.com] Cant find it in database. Are you sure this it exists?e[0m
03-21 21:37:51 INFO e[0m[core.media.movie.searcher] Search for Title ignoring ETAe[0m
03-21 21:37:52 INFO e[0m[hpotato.core.plugins.base] Opening url: get http://localhost:9117e[0m
03-30 17:22:18
I’m really only concerned with the first 3 so if steps dramatically change between them; they don’t have to be included. Any suggestions?
Thanks!!!
