How can I backup graylog settings? I’ve used content packs, where I export everything into json, however it’s not sufficient since alarm conditions are not exported.
I’d like to be able to start new graylog node (using docker) with the same settings as some other instance.
graylog settings are stored in mongodb, db is graylog.
So backing up this database is the answer to your title.
But, in your message, it seems you are trying to setup a multi instance platform.
In this case, just configure your new graylog node to use the existing mondodb server.
