AWS ClousTrail plugin behid proxy
Greetings,
Install: AWS AMI
Graylog: v2.3.2
AWS plugin: v2.3.1
I run graylog java instance with -Dhttp.proxyHost, -Dhttp.proxyPort and -Dhttp.nonProxyHosts options.
The all infrastructure is behind of corporate proxy. The all aws endpoints are whitelisted on proxy server.
I checked proxy logs and there is no incoming connection to sqs from aws cloudtrail plugin. Graylog logs shows that the connection times out to AWS sqs service.
does aws plugin work behind proxy ?
For reference:
