Auditd hex2ascii conversion plugin
Plugin Initial release
Graylog plugin for converting hex-encoded string used in auditd logs into human readable format
@winnie22
graylog-plugin-auditd-hex2ascii
Installation
Download the plugin and place the .jar file in your Graylog plugin directory. The plugin directory is the plugins/ folder relative from your graylog-server directory by default and can be configured in your graylog.conf file.
Restart graylog-server and you are done.
Usage
Parse auditd logs ie. as described here. Create rule that convert hex-encoded string from cmd or proctitle field into human readable format.
rule "proctitle2ascii_auditd"
has_field("auditd_proctitle")
set_field("auditd_proctitle_ascii", hex2ascii(to_string($message.auditd_proctitle)));
Will result into fields:
auditd_proctitle: 636174002F6574632F7373682F737368645F636F6E666967
auditd_proctitle_ascii: cat /etc/ssh/sshd_config
