Archive Plugin File System Path Mounting
I have installed and set up archive plugins in both the graylog server which I have in cluster.
After that, there is file system path where I stored the graylog archive indexes
Next Step is I mounted this file system path (/tmp/graylog-archive) with my S3 bucket path
my query is whether it required to mount on both graylog server present in my cluster for any specific reason
or is it fine to have this mounting on any one graylog machine?
please look at the documentation: http://docs.graylog.org/en/2.3/pages/archiving/setup.html#archive-options
The backend need to be mounted on the master node.
