Hi everyone, it seems that the API is allowing to create COLLECTORS with broken forward_to inputs… If you put anything that is not a valid id it will break the WEB interface, preventing you to load the page…
This is a very annoying issue as it seems that the process of creating a new collector using the API is not clever enough to understand names for “forward_to” but only an ID of an output that you don’t have in the moment of creation!
It’s a very similar issue that was reported here before:
https://community.graylog.org/t/using-rest-api-to-create-collector-configs/5049/4
