In 3.1. I could easily add or remove fields to the ‘All messages’ table in a stream by ticking checkboxes in the left panel. But now I have to manually type fields’ names every time I refresh the page.
It’s rather annoying. Is there a way to save the set of fields for a stream?
I don’t have 3.1 anymore, because I upgraded to 3.2, but 3.2 have a lot more options in All messages widget. You can for example add fields in your own order and save all widgets as saved search and after that load. Unfortunately some of functions also missing in 3.2 such as sort by field, quick values.
