Alerts not working
I am new to graylog, so probably is a my fault, but i am facing problems with Alerts.
I am using Graylog 3.2.6+e255fcc on Ubuntu 20.04 LTS.
I am trying to make an Alert when a stream is not sending data, to monitor the status of the streams, but i recieve no alert at all. This is my configuration:
I have also tried to stop completely the stream from the source rsyslog, but no alert is generated.
How i can debug this problem?
Cordially,
Claudio.
Check this:
https://support.graylog.com/help/en-us/13-alerts-notifications/53-content-pack-event-source-not-sending-logs
Thank you for your response, but it seems not working properly.
Now i see the events correctly generated, but wrong.
I have made this test: i have 2 sources, i have stopped 1 and the other is continuing sending logs.
After waiting for the Alerts been triggered, i have recieved 2 events of “30 minutes silent sender”, for all the two streams. But i have checked and the other stream is sended data in the last 10 minutes.
Something is wrong, but i don’t know how to debug the problem.
