Alerting Slack Integration
Hi everyone,
I just integrated Slack and Graylog and everything is working fine. But i’m trying to add stream url in notification.
For email , that’s easy, in body just add ${stream_url}. But when it comes to Slack, its problem, it should go in custom fields, but how to use it?
That’s currently not possible with the Graylog Slack plugin.
Please subscribe to the following GitHub issue for a possible solution to this:
https://github.com/graylog-labs/graylog-plugin-slack/issues/10
Tnx,
do you maybe know when will this pull rrequest be merged https://github.com/graylog-labs/graylog-plugin-slack/pull/50
It will be merged when someone had time to review the pull request.
