Alert when certain source didn't receive logs within x minutes
Hi, I’m currently monitoring about ~500 devices’ logs (mostly windows os), and I find it really hard to keep track of every single device at once. I’ve been reading every posts about creating an alert whenever a source receive no log but those didn’t work for me as I want a specific alert like “Computer x received no log within y minutes”. Looking forward for the right way to solve this, thanks.
  • OS Information: Windows 10, 11
  • Package Version: Graylog v4.3.7
I have a similar version of this kind of alert to fire a notification when a stream is not receiving log, but to monitor sources is a different concept and I’m still finding a way to make this possible.
Help me brainstorming or discuss any idea that would work.
Hello && Welcome @kien227
Yeah, only way that is possible, or close too what you want would be something like this.
I created a widget just for source count like this…
So if it drops or increases I do know a device was added or removed. I have to match the list of source from the day before.
Might want to check in Github or ask for a feature request here
Yeah I’ve seen this solution. I think it would be a nice alternative way using card() function. However if I use this I will have to make a list of all 500 machines… which is not what I’m aiming for. I would prefer knowing which machine is absent. Thanks for your reply, I would consider this later.
For 500 Machines it would be worth it to script the creation of the alert. You can do this with the REST-API. When we put wlerts in based on scripts we mention this in the description, and also have a script to delete them all again based on the description. If we update, we delete them all and implement the new list.
