Activate preflight UI menu
I’ve installed graylog-server and after configuring it I had the preflight UI menu to configure datanode. I installed then graylog-datanode but after restarting graylog-server, preflight UI menu doesn’t show up anymore. Is there a way to have it so I can’t configure the first datanode?
OS Information: debian 12
Package Version:
  • graylog-datanode 6.0.3-1 amd64 Graylog data node
  • graylog-server 6.0.3-1 amd64 Graylog server
What steps have you already taken to try and solve the problem?
Tried to drop mongodb database but it doesn’t help
Than you for your help.
I’m stuck here without a clue on how to activate the preflight menu, any help would be appreciated.
