Absolute date range - not working
Hi guys.
I have a problem with search interface on web. When I set up an absolute date range, for example 1.10-4.10.2024 and in web I go on the next page everything works fine, but when I want to go to the last page, for example from the 1. page to the last page I receive same messages as in the 1. page.
However, when I export log, I have all messages from absolute time range in csv. Or when I am clicking one by one to the last page everything works fine.
  • OS Information:
    NAME=“AlmaLinux”
    VERSION=“9.4 (Seafoam Ocelot)”
    ID=“almalinux”
    ID_LIKE=“rhel centos fedora”
  • Package Version:
    graylog-server-6.0.7-1.x86_64
    opensearch-2.14.0-1.x86_64
    mongodb-org-database-6.0.15-1.el9.x86_64
    I do not know what you need in this case from this - service logs, configurations, environment variables, I can provide it on the request
Upgrade to the last version of graylog server
Maybe someone is facing the same problem and can provide the solution
Thank you for reporting this!
I was able to reproduce this and have opened a GitHub issue to track: Search page (Log Table Widget) pagination stops changing the page contents after a certain number of pages · Issue #20644 · Graylog2/graylog2-server · GitHub
Thanks for the information :slight_smile:
Most likely this:
GL can do better at surfacing the problem; but in the end it’s due to your OS/ES configuration.
Hi all
Do you have any updates?
@bnerusil Have you tried increasing index.max_result_window?
Hi
Where can I increase this parameter, could you please provide me with some guide?
Hi. Sorry but I don’t understand where I have to put this command. Do I have to open some opensearch dashboard? I apologize for my question but I am not a developer.
Basic usage of Opensearch is beyond the scope of this forum.
Here is a good place to get started. It explains how to use the command line to manage ES/OS.
