for example
the indices name is graylog_123
how can i know what the directory in
elasticsearch/nodes/0/indices
any one helps
tks
for example
any one helps
tks
You’re not supposed to modify the on-disk structure of the Elasticsearch indices directly. You will likely corrupt your Elasticsearch cluster this way.
What do you want to achieve?
