Wrong IP running under docker gl2_remote_ip
Hello ,
I am running Graylog under docker ver 6.1 , i have some Inputs from Syslog UDP Pfsense , the issue i have is that the gl2_remote_ip field is written with docker IP instead of real syslog source IP , is there a setting or a way to set it to show real syslog gl2_remote_ip IP ,or diffrent field to look for the syslog source IP?
Thi is critical since i have several device that i need to identify between
Please advice Thanks
Hello @talbaror,
My suggestions would mirror those found on what I assume is your reddit post..
Look at the source field to identify where the log has come from.
