Hello Fellow GL enthusiasts!!
Trying to do a simple REGEX match on file names. I’m trying to pull out any file in the TargetFilename field that has a .aspx or .config or .cs or .php or .dll extension
Putting just .dll|.aspx doesn’t work
Here’s the syntax I tried, but it bombs out. Any insight is appreciated
rule “find message - Web Files”
regex("\\*.aspx|\\*.cs|\\*.config|\\*.php|\\*.dll", to_string($message.TargetFilename)).matches == true
You may want to try this one:
regex("\\.*\\.(aspx|cs|config|php|dll)$", to_string($message.TargetFileName))
Thanks…Just popped that in and tried it…no go…it doesn’t parse the file like web.config.
Are you sure that TargetFileName actually exists and contains the expected input? Other than that I have no idea why it wouldn’t work …
I think I see the issue… TargetFilename is the name of the field…not TargetFileName… case sensitive
Trying again
Yup…that was it…the field is TargetFilename … so your regex was right…and my fieldname was right…so between us…it works! Thanks
TP
