WaterMark settings on Graylog Cluster
Hi I tried to put in elasticsearch.yml below settings in elasticsearch node of my cluster
cluster.routing.allocation.disk.threshold_enabled: true
cluster.routing.allocation.disk.watermark.low: 30gb
cluster.routing.allocation.disk.watermark.high: 20gb
and I restarted my elastic search node, but its not reflecting when tried to get _cluster/settings
it still shows the previous value which I set using curl command
curl -XPUT 'localhost:9200/_cluster/settings?pretty' -H 'Content-Type: application/json' -d'{
      "transient": {
        "cluster.routing.allocation.disk.watermark.low": “90%",
        "cluster.routing.allocation.disk.watermark.high"`: “80%",
        "cluster.info.update.interval": "1m"
Please help me to know if I m missing something
I’d recommend asking this question in the Elasticsearch discussion forums:
Sure Thanks, I posted in elasticsearch forums as well with below link reference:
