For fun I decided to install Graylog 2.3.1 backed with Amazon’s ElasticSearch v5.5.
It almost works!
The [IndexerClusterCheckerThread] is throwing the following:
2017-09-15T17:13:28.505-04:00 ERROR [IndexerClusterCheckerThread] Uncaught exception in periodical
org.graylog2.indexer.ElasticsearchException: Unable to read Elasticsearch node information
at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:52) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:63) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.Cluster.catNodes(Cluster.java:119) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.Cluster.getFileDescriptorStats(Cluster.java:124) ~[graylog.jar:?]
at org.graylog2.periodical.IndexerClusterCheckerThread.doRun(IndexerClusterCheckerThread.java:56) ~[graylog.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_144]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_144]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_144]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_144]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_144]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_144]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_144]
Caused by: java.io.IOException: Request GET http://127.0.0.1:9201/_cat/nodes?h=name%2Chost%2CfileDescriptorMax&full_id=true HTTP/1.1 yielded text/plain;charset=UTF-8, should be json: HTTP/1.1 200 OK
at io.searchbox.client.http.JestHttpClient.deserializeResponse(JestHttpClient.java:224) ~[graylog.jar:?]
at io.searchbox.client.http.JestHttpClient.execute(JestHttpClient.java:88) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:47) ~[graylog.jar:?]
... 12 more
Caused by: com.fasterxml.jackson.core.JsonParseException: Unrecognized token 'nJFKmNg': was expecting 'null', 'true', 'false' or NaN
at [Source: nJFKmNg 128000
oMNpqyj 128000
; line: 1, column: 8]
at com.fasterxml.jackson.core.JsonParser._constructError(JsonParser.java:1702) ~[graylog.jar:?]
at com.fasterxml.jackson.core.base.ParserMinimalBase._reportError(ParserMinimalBase.java:558) ~[graylog.jar:?]
at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._reportInvalidToken(ReaderBasedJsonParser.java:2839) ~[graylog.jar:?]
at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._reportInvalidToken(ReaderBasedJsonParser.java:2812) ~[graylog.jar:?]
at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._matchToken(ReaderBasedJsonParser.java:2619) ~[graylog.jar:?]
at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._matchNull(ReaderBasedJsonParser.java:2602) ~[graylog.jar:?]
at com.fasterxml.jackson.core.json.ReaderBasedJsonParser.nextToken(ReaderBasedJsonParser.java:725) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.ObjectMapper._initForReading(ObjectMapper.java:3850) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.ObjectMapper._readMapAndClose(ObjectMapper.java:3799) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.ObjectMapper.readTree(ObjectMapper.java:2397) ~[graylog.jar:?]
at io.searchbox.core.Cat.parseResponseBody(Cat.java:53) ~[graylog.jar:?]
at io.searchbox.action.AbstractAction.createNewElasticSearchResult(AbstractAction.java:71) ~[graylog.jar:?]
at io.searchbox.core.Cat.createNewElasticSearchResult(Cat.java:44) ~[graylog.jar:?]
at io.searchbox.core.Cat.createNewElasticSearchResult(Cat.java:16) ~[graylog.jar:?]
at io.searchbox.client.http.JestHttpClient.deserializeResponse(JestHttpClient.java:211) ~[graylog.jar:?]
... 12 more
I do not see this with a local ES5.5 install.
Thoughts ?
-John
