/usr/lib/graylog-sidecar/filebeat: exec format error (Centos 6)
The problem is - the sidecar computer is seen in Graylog panel, but has issue
Graylog 2
  • OS Information:
    CentOS 6
  • Package Version:
    rpm -Uvh https://packages.graylog2.org/repo/packages/graylog-sidecar-repository-1-1.noarch.rpm
    sidecar.log from computer
    level=error msg="[filebeat] Couldn't start validation command: fork/exec /usr/lib/graylog-sidecar/filebeat: exec format error
This was the long installation to the Centos 6.
I had to try different sidecar versions until I found graylog-sidecar-repository-1-1.
I created executable “filebeat” file in “/usr/lib/graylog-sidecar” folder with the same permissions as in Centos7, bcs there was issue about “not found file”.
I added this to whitelist and accesslist in sidecar.yml.
And still I have “Couldn’t start validation command: fork/exec /usr/lib/graylog-sidecar/filebeat: exec format error” problem.
I hope, somebody installed it to CentOS6 and `ll advice me what to do for solving this quest.
Nobody knows how to solve issue at CentOS 6??? Rly?
Hey @vangog9,
Another user had a similar problem and used 1.0.2 release.
See here.
