Use of ${QUOTEDSTRING} causes Graylog to seize
We are creating a grok pattern to parse a complex log message that contains quoted strings with commas inside the quotes. Whenever we use the default ${QUOTEDSTRING} or ${QS} grok patterns against these logs, Graylog ceases the output of all logs to OpenSearch until the Graylog server is rebooted. The problem does not occur when the use of ${QUOTEDSTRING} or ${QS} is removed from the grok pattern.
We’re running Graylog 6.1 and OpenSearch 2.15 in a two-server configuration on a security hardened Oracle Linux 8 OS.
We found nothing in the Graylog server logs or OpenSearch cluster logs related to the issue.
  • How can we grok quoted strings with commas without using ${QUOTEDSTRING} or ${QS}?
  • How can we use ${QUOTEDSTRING} or ${QS} without Graylog seizing?
Searching for QUOTEDSTRING in this forum, I see a bunch of people are using it without encountering your issue. We are going to need more informaiton …
Are you using a grok input extractor or one of the grok functions in a pipeline rule?
Are there other inputs and do those all cease indexing?
Do you see messages in the Processing and Indexing Failures stream?
Please share a sanitized version of the pattern and the log data.
We’re using the grok function “Extract grok to fields” in a pipeline rule.
There is another separate input/stream/pipeline/index. Confirmed that all cease indexing.
“No failed indexing attempts in the last 24 hours.”
Pattern:
%{WORD:logsrc}.div.company.com %{NUMBER:num},%{DATA:receive_time},%{NUMBER:serial},%{WORD:type},%{WORD:subtype},%{NUMBER:port},%{DATA:time_generated},%{DATA:src},%{DATA:dst},%{DATA:natsrc},%{DATA:natdst},%{DATA:rule},%{DATA:srcuser},%{DATA:dstuser},%{DATA:app},%{DATA:vsys},%{DATA:from},%{DATA:to},%{DATA:inbound_if},%{DATA:outboundif},%{DATA:logset},%{DATA:unknown_time},%{NUMBER:sessionid},%{NUMBER:repeatcnt},%{NUMBER:sport},%{NUMBER:dport},%{NUMBER:natsport},%{NUMBER:natdport},%{DATA:flags},%{DATA:proto},%{DATA:action},%{NUMBER:bytes},%{NUMBER:bytes_sent},%{NUMBER:bytes_received},%{NUMBER:packets},%{DATA:start},%{NUMBER:elapsed},%{DATA:category},%{DATA:unknown_field1},%{DATA:seqno},%{DATA:actionflags},%{DATA:srcloc},%{DATA:dstloc},%{DATA:unknown_field2},%{DATA:pkts_sent},%{DATA:pkts_received},%{DATA:session_end_reason},%{DATA:dg_hier_level_1},%{DATA:dg_hier_level_2},%{DATA:dg_hier_level_3},%{DATA:dg_hier_level_4},%{DATA:vsys_name},%{DATA:device_name},%{DATA:action_source},%{DATA:src_uuid},%{DATA:dst_uuid},%{DATA:tunnelid},%{DATA:monitortag},%{DATA:parent_session_id},%{DATA:parent_start_time},%{DATA:tunnel},%{NUMBER:assoc_id},%{NUMBER:chunks},%{NUMBER:chunks_sent},%{NUMBER:chunks_received},%{DATA:rule_uuid},%{DATA:http2_connection},%{DATA:link_change_count},%{DATA:policy_id},%{DATA:link_switches},%{DATA:sdwan_cluster},%{DATA:sdwan_device_type},%{DATA:sdwan_cluster_type},%{DATA:sdwan_site},%{DATA:dynusergroup_name},%{DATA:xff_ip},%{DATA:src_category},%{DATA:src_profile},%{DATA:src_model},%{DATA:src_vendor},%{DATA:src_osfamily},%{DATA:src_osversion},%{DATA:src_host},%{DATA:src_mac},%{DATA:dst_category},%{DATA:dst_profile},%{DATA:dst_model},%{DATA:dst_vendor},%{DATA:dst_osfamily},%{DATA:dst_osversion},%{DATA:dst_host},%{DATA:dst_mac},%{DATA:container_id},%{DATA:pod_namespace},%{DATA:pod_name},%{DATA:src_edl},%{DATA:dst_edl},%{DATA:hostid},%{DATA:serialnumber},%{DATA:src_dag},%{DATA:dst_dag},%{DATA:session_owner},%{DATA:high_res_timestamp},%{DATA:nssai_sst},%{DATA:nssai_sd},%{DATA:subcategory_of_app},%{DATA:category_of_app},%{DATA:technology_of_app},%{DATA:risk_of_app},%{QUOTEDSTRING:characteristic_of_app},
Sample Data:
panorama01.div.company.com 1,2024/12/02 15:18:02,024101003988,TRAFFIC,end,2817,2024/12/02 15:18:02,10.101.19.7,10.101.159.130,0.0.0.0,0.0.0.0,inside-in_37,msrpc-base,vdiv1,PROD.Internal,PROD.DIVNET,ethernet1/2,ethernet1/1,default,2024/12/02 15:18:02,655765,1,61636,49681,0,0,0x401a,tcp,allow,4896,3798,1098,16,2024/12/02 15:17:19,29,any,7432514093394733498,0x8000000000000000,10.0.0.0-10.255.255.255,10.0.0.0-10.255.255.255,9,7,tcp-rst-from-client,20,11,0,0,PA2.NJ17,from-policy,0,0,N/A,0,0,0,0,1d654101-d3e3-774e-df69-82f43a334666,0,0,2024-12-02T15:18:02.940-05:00,infrastructure,networking,network-protocol,2,“has-known-vulnerability,tunnel-other-application,pervasive-use”,msrpc,untunneled,no,no,0,NonProxyTraffic,
It’s a PANOS TRAFFIC log - The “characteristic_of_app” field is quoted but contains commas. The “Test with Sample Data” button works, but if we press “Update Pattern” with the %{QUOTEDSTRING} included in the pattern, the output metric will go straight to zero and no further logs are indexed. If we just remove the %{QUOTEDSTRING} reference from the pattern (without rebooting the Graylog server) the output stays at zero. Commands to stop or restart the graylog-server service will just hang until we hit CTRL-C. If the server is rebooted with %{QUOTEDSTRING} removed from the pattern it will then resume as normal.
The pattern doesn’t match. I used https://grokdebugger.com/ to test and found that the last matching pattern is natsport. The rest of the message string is not matched. I was only using subsets of the pattern, so this didn’t involve QUOTEDSTRING at all.
As far as GL not indexing: I’m guessing that simply no message is being processed successfully.
