Hello, I am running 4.3.3 fine in Docker with ES and mongoDB,
as per docker-compose in the examples.
However when I try to update from 4.3.3 to anything newer I get the errors
- OS Information:
Host running Debian 10.2.1-6, Docker version 20.10.9
Intel 6th gen i7, 50gigs RAM
- Service logs, configurations, and environment variables:
graylog | #
graylog | # There is insufficient memory for the Java Runtime Environment to continue.
graylog | # Cannot create GC thread. Out of system resources.
graylog | # Can not save log file, dump to screen..
graylog | #
graylog | # Possible reasons:
graylog | # The system is out of physical RAM or swap space
graylog | # The process is running with CompressedOops enabled, and the Java Heap may be blocking the growth of the native heap
graylog | # Possible solutions:
graylog | # Reduce memory load on the system
graylog | # Increase physical memory or swap space
graylog | # Check if swap backing store is full
graylog | # Decrease Java heap size (-Xmx/-Xms)
graylog | # Decrease number of Java threads
graylog | # Decrease Java thread stack sizes (-Xss)
graylog | # Set larger code cache with -XX:ReservedCodeCacheSize=
graylog | # This output file may be truncated or incomplete.
graylog | #
graylog | # Out of Memory Error (gcTaskThread.cpp:48), pid=7, tid=0x00007f33cd93db80
graylog | #
graylog | # JRE version: (8.0_342-b07) (build )
graylog | # Java VM: OpenJDK 64-Bit Server VM (25.342-b07 mixed mode linux-amd64 compressed oops)
graylog | # Core dump written. Default location: /usr/share/graylog/core or core.7
graylog | #
graylog |
graylog | --------------- T H R E A D ---------------
graylog |
graylog | Current thread (0x00005628c33ca800): JavaThread "Unknown thread" [_thread_in_vm, id=7, stack(0x00007ffc500eb000,0x00007ffc501eb000)]
graylog |
graylog | Stack: [0x00007ffc500eb000,0x00007ffc501eb000], sp=0x00007ffc501e4230, free space=996k
graylog | Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
graylog | V [libjvm.so+0xb39a32] VMError::report_and_die()+0x2d2
graylog | V [libjvm.so+0x4e4917] report_vm_out_of_memory(char const*, int, unsigned long, VMErrorType, char const*)+0x67
graylog | V [libjvm.so+0x5cb24f] GCTaskThread::GCTaskThread(GCTaskManager*, unsigned int, unsigned int)+0x13f
graylog | V [libjvm.so+0x5ca3bd] GCTaskManager::initialize()+0x36d
graylog | V [libjvm.so+0x992b02] ParallelScavengeHeap::initialize()+0x3a2
graylog | V [libjvm.so+0xafcffa] Universe::initialize_heap()+0x16a
graylog | V [libjvm.so+0xafd2e3] universe_init()+0x33
graylog | V [libjvm.so+0x642e3d] init_globals()+0x5d
graylog | V [libjvm.so+0xadfbe1] Threads::create_vm(JavaVMInitArgs*, bool*)+0x4f1
graylog | V [libjvm.so+0x720f30] JNI_CreateJavaVM+0x50
graylog | C [libjli.so+0x7eb0] JavaMain+0x90
graylog | C [libjli.so+0xd8e9] ContinueInNewThread0+0x69
graylog | C [libjli.so+0x9c72] ContinueInNewThread+0x52
graylog | C [libjli.so+0xa380] JLI_Launch+0x5c0
graylog | C [java+0x651] main+0x41
graylog | C [libc.so.6+0x29d90]
graylog |
graylog |
graylog | --------------- P R O C E S S ---------------
graylog |
graylog | Java Threads: ( => current thread )
graylog |
graylog | Other Threads:
graylog |
graylog | =>0x00005628c33ca800 (exited) JavaThread "Unknown thread" [_thread_in_vm, id=7, stack(0x00007ffc500eb000,0x00007ffc501eb000)]
graylog |
graylog | VM state:not at safepoint (not fully initialized)
graylog |
graylog | VM Mutex/Monitor currently owned by a thread: None
graylog |
graylog | heap address: 0x0000000501200000, size: 12022 MB, Compressed Oops mode: Non-zero based:0x00000005011ff000, Oop shift amount: 3
graylog | Narrow klass base: 0x0000000000000000, Narrow klass shift: 0
graylog |
graylog | GC Heap History (0 events):
graylog | No events
graylog |
graylog | Deoptimization events (0 events):
graylog | No events
graylog |
graylog | Classes redefined (0 events):
graylog | No events
graylog |
graylog | Internal exceptions (0 events):
graylog | No events
graylog |
graylog | Events (0 events):
graylog | No events
graylog |
graylog |
graylog | Dynamic libraries:
graylog | 501200000-518a00000 rw-p 00000000 00:00 0
graylog | 518a00000-678d00000 ---p 00000000 00:00 0
graylog | 678d00000-690500000 rw-p 00000000 00:00 0
graylog | 690500000-7f0800000 ---p 00000000 00:00 0
graylog | 5628c1c00000-5628c1c01000 r-xp 00000000 08:01 9051749 /opt/java/openjdk/bin/java
graylog | 5628c1e00000-5628c1e01000 r--p 00000000 08:01 9051749 /opt/java/openjdk/bin/java
graylog | 5628c1e01000-5628c1e02000 rw-p 00001000 08:01 9051749 /opt/java/openjdk/bin/java
graylog | 5628c33ad000-5628c3411000 rw-p 00000000 00:00 0 [heap]
graylog | 7f33b9f06000-7f33b9fc2000 rw-p 00000000 00:00 0
graylog | 7f33b9fc2000-7f33baac4000 ---p 00000000 00:00 0
graylog | 7f33baac4000-7f33bab80000 rw-p 00000000 00:00 0
graylog | 7f33bab80000-7f33bb681000 ---p 00000000 00:00 0
graylog | 7f33bb681000-7f33bb73e000 rw-p 00000000 00:00 0
graylog | 7f33bb73e000-7f33bc23f000 ---p 00000000 00:00 0
graylog | 7f33bc23f000-7f33bc24a000 rw-p 00000000 00:00 0
graylog | 7f33bc24a000-7f33bc600000 ---p 00000000 00:00 0
graylog | 7f33bc600000-7f33bc870000 rwxp 00000000 00:00 0
graylog | 7f33bc870000-7f33cb600000 ---p 00000000 00:00 0
graylog | 7f33cb600000-7f33cb61b000 r-xp 00000000 08:01 19795252 /opt/java/openjdk/lib/amd64/libzip.so
graylog | 7f33cb61b000-7f33cb81a000 ---p 0001b000 08:01 19795252 /opt/java/openjdk/lib/amd64/libzip.so
graylog | 7f33cb81a000-7f33cb81b000 r--p 0001a000 08:01 19795252 /opt/java/openjdk/lib/amd64/libzip.so
graylog | 7f33cb81b000-7f33cb81c000 rw-p 0001b000 08:01 19795252 /opt/java/openjdk/lib/amd64/libzip.so
graylog | 7f33cba00000-7f33cba29000 r-xp 00000000 08:01 19795232 /opt/java/openjdk/lib/amd64/libjava.so
graylog | 7f33cba29000-7f33cbc28000 ---p 00029000 08:01 19795232 /opt/java/openjdk/lib/amd64/libjava.so
graylog | 7f33cbc28000-7f33cbc29000 r--p 00028000 08:01 19795232 /opt/java/openjdk/lib/amd64/libjava.so
graylog | 7f33cbc29000-7f33cbc2b000 rw-p 00029000 08:01 19795232 /opt/java/openjdk/lib/amd64/libjava.so
graylog | 7f33cbc5e000-7f33cbe00000 rw-p 00000000 00:00 0
graylog | 7f33cbe00000-7f33cbe0d000 r-xp 00000000 08:01 19795251 /opt/java/openjdk/lib/amd64/libverify.so
graylog | 7f33cbe0d000-7f33cc00c000 ---p 0000d000 08:01 19795251 /opt/java/openjdk/lib/amd64/libverify.so
graylog | 7f33cc00c000-7f33cc00e000 r--p 0000c000 08:01 19795251 /opt/java/openjdk/lib/amd64/libverify.so
graylog | 7f33cc00e000-7f33cc00f000 rw-p 0000e000 08:01 19795251 /opt/java/openjdk/lib/amd64/libverify.so
graylog | 7f33cc10c000-7f33cc200000 rw-p 00000000 00:00 0
graylog | 7f33cc200000-7f33ccf5e000 r-xp 00000000 08:01 19795256 /opt/java/openjdk/lib/amd64/server/libjvm.so
graylog | 7f33ccf5e000-7f33cd15d000 ---p 00d5e000 08:01 19795256 /opt/java/openjdk/lib/amd64/server/libjvm.so
graylog | 7f33cd15d000-7f33cd1f4000 r--p 00d5d000 08:01 19795256 /opt/java/openjdk/lib/amd64/server/libjvm.so
graylog | 7f33cd1f4000-7f33cd21d000 rw-p 00df4000 08:01 19795256 /opt/java/openjdk/lib/amd64/server/libjvm.so
graylog | 7f33cd21d000-7f33cd250000 rw-p 00000000 00:00 0
graylog | 7f33cd2d7000-7f33cd2d8000 ---p 00000000 00:00 0
graylog | 7f33cd2d8000-7f33cd3d8000 rw-p 00000000 00:00 0
graylog | 7f33cd3d8000-7f33cd400000 r--p 00000000 08:01 19667194 /usr/lib/x86_64-linux-gnu/libc.so.6
graylog | 7f33cd400000-7f33cd595000 r-xp 00028000 08:01 19667194 /usr/lib/x86_64-linux-gnu/libc.so.6
graylog | 7f33cd595000-7f33cd5ed000 r--p 001bd000 08:01 19667194 /usr/lib/x86_64-linux-gnu/libc.so.6
graylog | 7f33cd5ed000-7f33cd5f1000 r--p 00214000 08:01 19667194 /usr/lib/x86_64-linux-gnu/libc.so.6
graylog | 7f33cd5f1000-7f33cd5f3000 rw-p 00218000 08:01 19667194 /usr/lib/x86_64-linux-gnu/libc.so.6
graylog | 7f33cd5f3000-7f33cd600000 rw-p 00000000 00:00 0
graylog | 7f33cd600000-7f33cd617000 r-xp 00000000 08:01 19795219 /opt/java/openjdk/lib/amd64/jli/libjli.so
graylog | 7f33cd617000-7f33cd816000 ---p 00017000 08:01 19795219 /opt/java/openjdk/lib/amd64/jli/libjli.so
graylog | 7f33cd816000-7f33cd817000 r--p 00016000 08:01 19795219 /opt/java/openjdk/lib/amd64/jli/libjli.so
graylog | 7f33cd817000-7f33cd818000 rw-p 00017000 08:01 19795219 /opt/java/openjdk/lib/amd64/jli/libjli.so
graylog | 7f33cd849000-7f33cd851000 rw-p 00000000 00:00 0
graylog | 7f33cd851000-7f33cd852000 r--p 00000000 08:01 19667291 /usr/lib/x86_64-linux-gnu/librt.so.1
graylog | 7f33cd852000-7f33cd853000 r-xp 00001000 08:01 19667291 /usr/lib/x86_64-linux-gnu/librt.so.1
graylog | 7f33cd853000-7f33cd854000 r--p 00002000 08:01 19667291 /usr/lib/x86_64-linux-gnu/librt.so.1
graylog | 7f33cd854000-7f33cd855000 r--p 00002000 08:01 19667291 /usr/lib/x86_64-linux-gnu/librt.so.1
graylog | 7f33cd855000-7f33cd856000 rw-p 00003000 08:01 19667291 /usr/lib/x86_64-linux-gnu/librt.so.1
graylog | 7f33cd856000-7f33cd864000 r--p 00000000 08:01 19667246 /usr/lib/x86_64-linux-gnu/libm.so.6
graylog | 7f33cd864000-7f33cd8e0000 r-xp 0000e000 08:01 19667246 /usr/lib/x86_64-linux-gnu/libm.so.6
graylog | 7f33cd8e0000-7f33cd93b000 r--p 0008a000 08:01 19667246 /usr/lib/x86_64-linux-gnu/libm.so.6
graylog | 7f33cd93b000-7f33cd93c000 r--p 000e4000 08:01 19667246 /usr/lib/x86_64-linux-gnu/libm.so.6
graylog | 7f33cd93c000-7f33cd93d000 rw-p 000e5000 08:01 19667246 /usr/lib/x86_64-linux-gnu/libm.so.6
graylog | 7f33cd93d000-7f33cd93f000 rw-p 00000000 00:00 0
graylog | 7f33cd93f000-7f33cd940000 r--p 00000000 08:01 19667208 /usr/lib/x86_64-linux-gnu/libdl.so.2
graylog | 7f33cd940000-7f33cd941000 r-xp 00001000 08:01 19667208 /usr/lib/x86_64-linux-gnu/libdl.so.2
graylog | 7f33cd941000-7f33cd942000 r--p 00002000 08:01 19667208 /usr/lib/x86_64-linux-gnu/libdl.so.2
graylog | 7f33cd942000-7f33cd943000 r--p 00002000 08:01 19667208 /usr/lib/x86_64-linux-gnu/libdl.so.2
graylog | 7f33cd943000-7f33cd944000 rw-p 00003000 08:01 19667208 /usr/lib/x86_64-linux-gnu/libdl.so.2
graylog | 7f33cd944000-7f33cd945000 r--p 00000000 08:01 19667289 /usr/lib/x86_64-linux-gnu/libpthread.so.0
graylog | 7f33cd945000-7f33cd946000 r-xp 00001000 08:01 19667289 /usr/lib/x86_64-linux-gnu/libpthread.so.0
graylog | 7f33cd946000-7f33cd947000 r--p 00002000 08:01 19667289 /usr/lib/x86_64-linux-gnu/libpthread.so.0
graylog | 7f33cd947000-7f33cd948000 r--p 00002000 08:01 19667289 /usr/lib/x86_64-linux-gnu/libpthread.so.0
graylog | 7f33cd948000-7f33cd949000 rw-p 00003000 08:01 19667289 /usr/lib/x86_64-linux-gnu/libpthread.so.0
graylog | 7f33cd94b000-7f33cd94e000 rw-p 00000000 00:00 0
graylog | 7f33cd94e000-7f33cd950000 r--p 00000000 08:01 19667176 /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
graylog | 7f33cd950000-7f33cd97a000 r-xp 00002000 08:01 19667176 /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
graylog | 7f33cd97a000-7f33cd985000 r--p 0002c000 08:01 19667176 /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
graylog | 7f33cd985000-7f33cd986000 r--p 00000000 00:00 0
graylog | 7f33cd986000-7f33cd988000 r--p 00037000 08:01 19667176 /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
graylog | 7f33cd988000-7f33cd98a000 rw-p 00039000 08:01 19667176 /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
graylog | 7ffc500eb000-7ffc500ee000 ---p 00000000 00:00 0
graylog | 7ffc500ee000-7ffc501eb000 rw-p 00000000 00:00 0 [stack]
graylog | 7ffc501ef000-7ffc501f3000 r--p 00000000 00:00 0 [vvar]
graylog | 7ffc501f3000-7ffc501f5000 r-xp 00000000 00:00 0 [vdso]
graylog |
graylog | VM Arguments:
graylog | jvm_args: -Dlog4j2.formatMsgNoLookups=true -Djdk.tls.acknowledgeCloseNotify=true -XX:+UnlockExperimentalVMOptions -XX:NewRatio=1 -XX:MaxMetaspaceSize=256m -XX:+ResizeTLAB -XX:-OmitStackTraceInFastThrow -Dlog4j.configurationFile=/usr/share/graylog/data/config/log4j2.xml -Djava.library.path=/usr/share/graylog/lib/sigar/ -Dgraylog2.installation_source=docker
graylog | java_command: /usr/share/graylog/graylog.jar server -f /usr/share/graylog/data/config/graylog.conf
graylog | java_class_path (initial): /usr/share/graylog/graylog.jar
graylog | Launcher Type: SUN_STANDARD
graylog |
graylog | Environment Variables:
graylog | JAVA_HOME=/opt/java/openjdk
graylog | PATH=/usr/share/graylog/bin:/opt/java/openjdk/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
graylog |
graylog | Signal Handlers:
graylog | SIGSEGV: [libjvm.so+0xb3b0d0], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
graylog | SIGBUS: [libjvm.so+0xb3b0d0], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
graylog | SIGFPE: [libjvm.so+0x963540], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
graylog | SIGPIPE: [libjvm.so+0x963540], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
graylog | SIGXFSZ: [libjvm.so+0x963540], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
graylog | SIGILL: [libjvm.so+0x963540], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
graylog | SIGUSR1: SIG_DFL, sa_mask[0]=00000000000000000000000000000000, sa_flags=none
graylog | SIGUSR2: [libjvm.so+0x963af0], sa_mask[0]=00000000000000000000000000000000, sa_flags=SA_RESTART|SA_SIGINFO
graylog | SIGHUP: SIG_DFL, sa_mask[0]=00000000000000000000000000000000, sa_flags=none
graylog | SIGINT: SIG_DFL, sa_mask[0]=00000000000000000000000000000000, sa_flags=none
graylog | SIGTERM: SIG_DFL, sa_mask[0]=00000000000000000000000000000000, sa_flags=none
graylog | SIGQUIT: SIG_DFL, sa_mask[0]=00000000000000000000000000000000, sa_flags=none
graylog |
graylog |
graylog | --------------- S Y S T E M ---------------
graylog |
graylog | OS:DISTRIB_ID=Ubuntu
graylog | DISTRIB_RELEASE=22.04
graylog | DISTRIB_CODENAME=jammy
graylog | DISTRIB_DESCRIPTION="Ubuntu 22.04.1 LTS"
graylog |
graylog | uname:Linux 5.10.0-9-amd64 #1 SMP Debian 5.10.70-1 (2021-09-30) x86_64
graylog | libc:glibc 2.35 NPTL 2.35
graylog | rlimit: STACK 8192k, CORE infinity, NPROC infinity, NOFILE 1048576, AS infinity
graylog | load average:0.72 2.07 1.80
graylog |
graylog | /proc/meminfo:
graylog | MemTotal: 49235732 kB
graylog | MemFree: 30577328 kB
graylog | MemAvailable: 41621804 kB
graylog | Buffers: 1609152 kB
graylog | Cached: 8783056 kB
graylog | SwapCached: 0 kB
graylog | Active: 3644104 kB
graylog | Inactive: 11604136 kB
graylog | Active(anon): 27708 kB
graylog | Inactive(anon): 5072876 kB
graylog | Active(file): 3616396 kB
graylog | Inactive(file): 6531260 kB
graylog | Unevictable: 1549056 kB
graylog | Mlocked: 1548940 kB
graylog | SwapTotal: 0 kB
graylog | SwapFree: 0 kB
graylog | Dirty: 138168 kB
graylog | Writeback: 0 kB
graylog | AnonPages: 6328744 kB
graylog | Mapped: 1062900 kB
graylog | Shmem: 70796 kB
graylog | KReclaimable: 1496836 kB
graylog | Slab: 1668332 kB
graylog | SReclaimable: 1496836 kB
graylog | SUnreclaim: 171496 kB
graylog | KernelStack: 27408 kB
graylog | PageTables: 44068 kB
graylog | NFS_Unstable: 0 kB
graylog | Bounce: 0 kB
graylog | WritebackTmp: 0 kB
graylog | CommitLimit: 24617864 kB
graylog | Committed_AS: 23322868 kB
graylog | VmallocTotal: 34359738367 kB
graylog | VmallocUsed: 54196 kB
graylog | VmallocChunk: 0 kB
graylog | Percpu: 7872 kB
graylog | HardwareCorrupted: 0 kB
graylog | AnonHugePages: 4806656 kB
graylog | ShmemHugePages: 0 kB
graylog | ShmemPmdMapped: 0 kB
graylog | FileHugePages: 0 kB
graylog | FilePmdMapped: 0 kB
graylog | HugePages_Total: 0
graylog | HugePages_Free: 0
graylog | HugePages_Rsvd: 0
graylog | HugePages_Surp: 0
graylog | Hugepagesize: 2048 kB
graylog | Hugetlb: 0 kB
graylog | DirectMap4k: 552592 kB
graylog | DirectMap2M: 25548800 kB
graylog | DirectMap1G: 24117248 kB
graylog |
graylog |
graylog | CPU:total 8 (initial active 8) (4 cores per cpu, 2 threads per core) family 6 model 94 stepping 3, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, avx2, aes, clmul, erms, rtm, 3dnowpref, lzcnt, ht, tsc, tscinvbit, bmi1, bmi2, adx
graylog |
graylog | /proc/cpuinfo:
graylog | processor : 0
graylog | vendor_id : GenuineIntel
graylog | cpu family : 6
graylog | model : 94
graylog | model name : Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
graylog | stepping : 3
graylog | microcode : 0xea
graylog | cpu MHz : 3696.773
graylog | cache size : 8192 KB
graylog | physical id : 0
graylog | siblings : 8
graylog | core id : 0
graylog | cpu cores : 4
graylog | apicid : 0
graylog | initial apicid : 0
graylog | fpu : yes
graylog | fpu_exception : yes
graylog | cpuid level : 22
graylog | wp : yes
graylog | flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb invpcid_single pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp md_clear flush_l1d
graylog | vmx flags : vnmi preemption_timer invvpid ept_x_only ept_ad ept_1gb flexpriority tsc_offset vtpr mtf vapic ept vpid unrestricted_guest ple shadow_vmcs pml
graylog | bugs : cpu_meltdown spectre_v1 spectre_v2 spec_store_bypass l1tf mds swapgs taa itlb_multihit srbds
graylog | bogomips : 6799.81
graylog | clflush size : 64
graylog | cache_alignment : 64
graylog | address sizes : 39 bits physical, 48 bits virtual
graylog | power management:
graylog |
graylog | processor : 1
graylog | cpu MHz : 3655.685
graylog | core id : 1
graylog | apicid : 2
graylog | initial apicid : 2
graylog | fpu : yes
graylog | wp : yes
---------- Intel CPU thingies -------
graylog |
graylog |
graylog |
graylog | Memory: 4k page, physical 49235732k(30577328k free), swap 0k(0k free)
graylog |
graylog | vm_info: OpenJDK 64-Bit Server VM (25.342-b07) for linux-amd64 JRE (1.8.0_342-b07), built on Jul 22 2022 08:47:00 by "jenkins" with gcc 7.5.0
graylog |
graylog | time: Tue Sep 27 08:56:18 2022
graylog | timezone: UTC
graylog | elapsed time: 0.005725 seconds (0d 0h 0m 0s)
graylog |
Anything > 4.3.3 is not going to start up for me ![]()
I have no idea what is going wrong here,
maybe someone can see more than me.
Thank you ![]()
