Updated from v2.2 to v2.3 : Can't reach ElasticSearch
I upgraded us from 2.1 to 2.2 without issue. But when I tried to go from v2.2 to v2.3 I have run into a problem, it seems Graylog can no longer reach Elasticsearch. When I start the graylog-server service I see entries like:
2018-04-14T17:45:40.427-04:00 ERROR [Cluster] Couldn’t read cluster health for indices [graylog2_*] (Could not connect to http://127.0.0.1:9200)
I know my ElasticSearch is fine:
curl -XGET ‘http://localhost:9200/_cluster/health?pretty=true’
“cluster_name” : “locker”,
“status” : “green”,
“timed_out” : false,
“number_of_nodes” : 1,
“number_of_data_nodes” : 1,
“active_primary_shards” : 360,
“active_shards” : 360,
“relocating_shards” : 0,
“initializing_shards” : 0,
“unassigned_shards” : 0,
“delayed_unassigned_shards” : 0,
“number_of_pending_tasks” : 0,
“number_of_in_flight_fetch” : 0,
“task_max_waiting_in_queue_millis” : 0,
“active_shards_percent_as_number” : 100.0
Per http://docs.graylog.org/en/2.4/pages/upgrade/graylog-2.3.html I tried setting “elasticsearch_hosts” in my server.conf to:
elasticsearch_host = http://10.0.0.1:9200/
But I’m still not having luck getting Graylog and ElasticSearch to talk. What did I miss? Can anyone point me in the right direction?
without knowing your server.conf before and after your upgrade it is not possible to tell what is wrong.
You should check the removed parameter and the added ones in the docs you already refer to.
Thanks for responding Jan.
Here is my server.conf, as far as I know nothing was changed when updating, except for the elasticsearch_host line I added when troubleshooting, from what I understood on the update article that was only thing that was required.
## Global
is_master = true
password_secret = *REMOVED*
root_password_sha2 = *REMOVED*
root_email = "*REMOVED*"
root_timezone = America/Toronto
rules_file = /etc/graylog/server/rules.drl
ldap_connection_timeout = 5000
alert_check_interval = 45
## REST API & Web
rest_listen_uri = http://0.0.0.0:12900/
rest_transport_uri = http://10.1.115.2:12900/
web_enable = true
web_listen_uri = http://127.0.0.1:9000/
## Search
allow_highlighting = false
## Elasticsearch
elasticsearch_host = http://127.0.0.1:9200/
elasticsearch_shards = 1
elasticsearch_replicas = 0
elasticsearch_index_prefix = graylog2
elasticsearch_cluster_name = locker
elasticsearch_node_name_prefix = graylog-
elasticsearch_discovery_zen_ping_multicast_enabled = false
elasticsearch_discovery_zen_ping_unicast_hosts = 10.1.115.2:9300
elasticsearch_transport_tcp_port = 9350
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
## Message Journal
message_journal_dir = /mnt/store1/graylog-server/journal/
message_journal_max_age = 72h
message_journal_max_size = 150gb
message_journal_flush_age = 1m
message_journal_flush_interval = 1000000
message_journal_segment_age = 1h
message_journal_segment_size = 400mb
## MongoDB
mongodb_uri = *REMOVED*
# Email transport
transport_email_hostname = *REMOVED*
transport_email_port = 25
transport_email_use_tls = false
transport_email_subject_prefix = [Graylog]
transport_email_from_email = *REMOVED*
transport_email_web_interface_url = *REMOVED*
# Content Packs
content_packs_loader_enabled = false
#content_packs_dir = data/contentpacks
#content_packs_auto_load = grok-patterns.json
# Plugins
usage_statistics_enabled = false
dns_resolver_enabled = true
dns_resolver_run_before_extractors = true
Here is Elasticsearch.yml:
> # ======================== Elasticsearch Configuration =========================
> # NOTE: Elasticsearch comes with reasonable defaults for most settings.
> #       Before you set out to tweak and tune the configuration, make sure you
> #       understand what are you trying to accomplish and the consequences.
> # The primary way of configuring a node is via this file. This template lists
> # the most important settings you may want to configure for a production cluster.
> # Please see the documentation for further information on configuration options:
> # <http://www.elastic.co/guide/en/elasticsearch/reference/current/setup-configuration.html>
> # ---------------------------------- Cluster -----------------------------------
> # Use a descriptive name for your cluster:
> # cluster.name: my-application
> cluster.name: locker
> # ------------------------------------ Node ------------------------------------
> # Use a descriptive name for the node:
> # node.name: graylog-1
> # Add custom attributes to the node:
> # node.rack: r1
> # ----------------------------------- Paths ------------------------------------
> # Path to directory where to store the data (separate multiple locations by comma):
> # path.data: /path/to/data
> path.data: /mnt/store1/elasticsearch/data
> # Path to log files:
> # path.logs: /path/to/logs
> path.logs: /mnt/store1/elasticsearch/logs
> path.work: /mnt/store1/elasticsearch/work
> path.plugins: /mnt/store1/elasticsearch/plugins
> path.repo: ["/mnt/store1/backups/graylog-mongodb-elasticsearch/elasticsearch"]
> # ----------------------------------- Memory -----------------------------------
> # Lock the memory on startup:
> bootstrap.mlockall: true
> # Make sure that the `ES_HEAP_SIZE` environment variable is set to about half the memory
> # available on the system and that the owner of the process is allowed to use this limit.
> # Elasticsearch performs poorly when the system is swapping the memory.
> # ---------------------------------- Network -----------------------------------
> # Set the bind address to a specific IP (IPv4 or IPv6):
> network.host: 10.1.115.2
> # Set a custom port for HTTP:
> # http.port: 9200
> # For more information, see the documentation at:
> # <http://www.elastic.co/guide/en/elasticsearch/reference/current/modules-network.html>
> # --------------------------------- Discovery ----------------------------------
> # Pass an initial list of hosts to perform discovery when new node is started:
> # The default list of hosts is ["127.0.0.1", "[::1]"]
> discovery.zen.ping.multicast.enabled: false
> discovery.zen.ping.unicast.hosts: ["10.1.115.2"]
> # Prevent the "split brain" by configuring the majority of nodes (total number of nodes / 2 + 1):
> # discovery.zen.minimum_master_nodes: 1
> # <http://www.elastic.co/guide/en/elasticsearch/reference/current/modules-discovery.html>
> # ---------------------------------- Gateway -----------------------------------
> # Block initial recovery after a full cluster restart until N nodes are started:
> # gateway.recover_after_nodes: 1
> # <http://www.elastic.co/guide/en/elasticsearch/reference/current/modules-gateway.html>
> # ---------------------------------- Various -----------------------------------
> # Disable starting multiple nodes on a single system:
> # node.max_local_storage_nodes: 1
> # Require explicit names when deleting indices:
> # action.destructive_requires_name: true
> # Disable the dynamic scripting feature and prevent possible remote code executions.
> script.inline: false
> script.indexed: false
> script.file: false
Please advise how to proceed. Thanks in advance!
You have a different IP for your elasticsearch in your elasticsearch.yml and in the elasticsearch_host line in the graylog.conf. If you don’t bind your elasticsearch in your loopback interface, you cannot reach it there.
Hi Jan, my mistake, that was just a test when I tried using the loopback, I was getting the same result with both IP’s set to 10.1.115.2.
I have added all the settings from your Upgrade guide linked earlier, most using the defaults. Here is a revised version of my server.conf and elasticsearch.yml, also my server.log. Would you mind looking it over again and pointing me in the right direction?
## Global
is_master = true
root_email = *REMOVED*
## REST API & Web
web_enable = true
## Search
## Elasticsearch
ring_size = 65536
##### REMOVED IN v2.3
# elasticsearch_transport_tcp_port = 9350
# elasticsearch_node_name_prefix = graylog-
##### ADDED IN v2.3
elasticsearch_host = http://10.1.115.2:9200
elasticsearch_connect_timeout = 10s
# elasticsearch_idle_timeout = 999
elasticsearch_max_total_connections = 20
elasticsearch_max_total_connections_per_route = 2
elasticsearch_max_retries = 2
elasticsearch_socket_timeout = 60s
elasticsearch_discovery_enabled = false
elasticsearch_discovery_filter =
elasticsearch_discovery_frequency = 30s
## Message Journal
## MongoDB
# Email transport
# Content Packs
# content_packs_dir = data/contentpacks
# content_packs_auto_load = grok-patterns.json
# Plugins
elasticsearch.yml, comments removed:
script.file: false
When I start using this config I get this message in server.log:
2018-04-16T13:41:30.037-04:00 ERROR [Cluster] Couldn't read cluster health for indices [graylog2_*] (Could not connect to http://127.0.0.1:9200)
I’m not sure why it’s using the loop back there. Where is this set? Curl test below:
[locker graylog-server]# curl -XGET 'http://127.0.0.1:9200/_cluster/health'
curl: (7) Failed connect to 127.0.0.1:9200; Connection refused
[locker graylog-server]# curl -XGET 'http://10.1.115.2:9200/_cluster/health'
{"cluster_name":"locker","status":"green","timed_out":false,"number_of_nodes":1,"number_of_data_nodes":1,"active_primary_shards":360,"active_shards":360,"relocating_shards":0,"initializing_shards":0,"unassigned_shards":0,"delayed_unassigned_shards":0,"number_of_pending_tasks":0,"number_of_in_flight_fetch":0,"task_max_waiting_in_queue_millis":0,"active_shards_percent_as_number":100.0}
Here is the full server.log:
2018-04-16T13:41:25.506-04:00 INFO  [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=rpm
2018-04-16T13:41:25.694-04:00 INFO  [Version] HV000001: Hibernate Validator null
2018-04-16T13:41:27.234-04:00 INFO  [InputBufferImpl] Message journal is enabled.
2018-04-16T13:41:27.254-04:00 INFO  [NodeId] Node ID: a002c9da-98ce-4e77-9564-89915b10fd30
2018-04-16T13:41:27.429-04:00 INFO  [LogManager] Loading logs.
2018-04-16T13:41:27.473-04:00 INFO  [LogManager] Logs loading complete.
2018-04-16T13:41:27.473-04:00 INFO  [KafkaJournal] Initialized Kafka based journal at /mnt/store1/graylog-server/journal
2018-04-16T13:41:27.486-04:00 INFO  [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy <BlockingWaitStrategy>, running 2 parallel message handlers.
2018-04-16T13:41:27.503-04:00 INFO  [cluster] Cluster created with settings {hosts=[127.0.0.1:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=5000}
2018-04-16T13:41:27.541-04:00 INFO  [cluster] No server chosen by ReadPreferenceServerSelector{readPreference=primary} from cluster description ClusterDescription{type=UNKNOWN, connectionMode=SINGLE, serverDescriptions=[ServerDescription{address=127.0.0.1:27017, type=UNKNOWN, state=CONNECTING}]}. Waiting for 30000 ms before timing out
2018-04-16T13:41:27.556-04:00 INFO  [connection] Opened connection [connectionId{localValue:1, serverValue:87}] to 127.0.0.1:27017
2018-04-16T13:41:27.557-04:00 INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=127.0.0.1:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[2, 6, 11]}, minWireVersion=0, maxWireVersion=2, maxDocumentSize=16777216, roundTripTimeNanos=400970}
2018-04-16T13:41:27.563-04:00 INFO  [connection] Opened connection [connectionId{localValue:2, serverValue:88}] to 127.0.0.1:27017
2018-04-16T13:41:27.819-04:00 INFO  [AbstractJestClient] Setting server pool to a list of 1 servers: [http://127.0.0.1:9200]
2018-04-16T13:41:27.820-04:00 INFO  [JestClientFactory] Using multi thread/connection supporting pooling connection manager
2018-04-16T13:41:27.879-04:00 INFO  [JestClientFactory] Using custom ObjectMapper instance
2018-04-16T13:41:27.879-04:00 INFO  [JestClientFactory] Node Discovery disabled...
2018-04-16T13:41:27.880-04:00 INFO  [JestClientFactory] Idle connection reaping disabled...
2018-04-16T13:41:28.080-04:00 INFO  [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2018-04-16T13:41:29.616-04:00 INFO  [RulesEngineProvider] Using rules: /etc/graylog/server/rules.drl
2018-04-16T13:41:29.703-04:00 INFO  [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2018-04-16T13:41:29.957-04:00 INFO  [ServerBootstrap] Graylog server 2.3.2+3df951e starting up
2018-04-16T13:41:29.957-04:00 INFO  [ServerBootstrap] JRE: Oracle Corporation 1.8.0_91 on Linux 3.10.0-229.20.1.el7.x86_64
2018-04-16T13:41:29.957-04:00 INFO  [ServerBootstrap] Deployment: rpm
2018-04-16T13:41:29.957-04:00 INFO  [ServerBootstrap] OS: CentOS Linux 7 (Core) (centos)
2018-04-16T13:41:29.958-04:00 INFO  [ServerBootstrap] Arch: amd64
2018-04-16T13:41:29.960-04:00 WARN  [DeadEventLoggingListener] Received unhandled event of type <org.graylog2.plugin.lifecycles.Lifecycle> from event bus <AsyncEventBus{graylog-eventbus}>
2018-04-16T13:41:29.978-04:00 INFO  [PeriodicalsService] Starting 22 periodicals ...
2018-04-16T13:41:29.979-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ThroughputCalculator] periodical in [0s], polling every [1s].
2018-04-16T13:41:29.981-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.AlertScannerThread] periodical in [10s], polling every [45s].
2018-04-16T13:41:29.982-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] periodical in [0s], polling every [1s].
2018-04-16T13:41:29.984-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ClusterHealthCheckThread] periodical in [120s], polling every [20s].
2018-04-16T13:41:29.984-04:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.ContentPackLoaderPeriodical] periodical. Not configured to run on this node.
2018-04-16T13:41:29.984-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.GarbageCollectionWarningThread] periodical, running forever.
2018-04-16T13:41:29.985-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexerClusterCheckerThread] periodical in [0s], polling every [30s].
2018-04-16T13:41:29.986-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRetentionThread] periodical in [0s], polling every [300s].
2018-04-16T13:41:29.987-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRotationThread] periodical in [0s], polling every [10s].
2018-04-16T13:41:29.988-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.NodePingThread] periodical in [0s], polling every [1s].
2018-04-16T13:41:29.989-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.VersionCheckThread] periodical in [300s], polling every [1800s].
2018-04-16T13:41:29.990-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ThrottleStateUpdaterThread] periodical in [1s], polling every [1s].
2018-04-16T13:41:29.990-04:00 INFO  [Periodicals] Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
2018-04-16T13:41:29.991-04:00 INFO  [Periodicals] Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
2018-04-16T13:41:29.991-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ClusterIdGeneratorPeriodical] periodical, running forever.
2018-04-16T13:41:29.992-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRangesMigrationPeriodical] periodical, running forever.
2018-04-16T13:41:29.992-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical in [15s], polling every [3600s].
2018-04-16T13:41:29.992-04:00 INFO  [connection] Opened connection [connectionId{localValue:3, serverValue:89}] to 127.0.0.1:27017
2018-04-16T13:41:29.992-04:00 INFO  [connection] Opened connection [connectionId{localValue:4, serverValue:90}] to 127.0.0.1:27017
2018-04-16T13:41:29.999-04:00 INFO  [connection] Opened connection [connectionId{localValue:5, serverValue:91}] to 127.0.0.1:27017
2018-04-16T13:41:30.002-04:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.UserPermissionMigrationPeriodical] periodical. Not configured to run on this node.
2018-04-16T13:41:30.002-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.AlarmCallbacksMigrationPeriodical] periodical, running forever.
2018-04-16T13:41:30.002-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ConfigurationManagementPeriodical] periodical, running forever.
2018-04-16T13:41:30.006-04:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.LdapGroupMappingMigration] periodical. Not configured to run on this node.
2018-04-16T13:41:30.007-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexFailuresPeriodical] periodical, running forever.
2018-04-16T13:41:30.036-04:00 INFO  [IndexRetentionThread] Elasticsearch cluster not available, skipping index retention checks.
2018-04-16T13:41:30.037-04:00 INFO  [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2018-04-16T13:41:30.046-04:00 INFO  [JerseyService] Enabling CORS for HTTP endpoint
2018-04-16T13:41:30.051-04:00 INFO  [V20161130141500_DefaultStreamRecalcIndexRanges] Cluster not connected yet, delaying migration until it is reachable.
2018-04-16T13:41:37.817-04:00 INFO  [NetworkListener] Started listener bound to [0.0.0.0:12900]
2018-04-16T13:41:37.818-04:00 INFO  [HttpServer] [HttpServer] Started.
2018-04-16T13:41:37.818-04:00 INFO  [JerseyService] Started REST API at <http://0.0.0.0:12900/>
2018-04-16T13:41:39.996-04:00 INFO  [NetworkListener] Started listener bound to [127.0.0.1:9000]
2018-04-16T13:41:39.997-04:00 INFO  [HttpServer] [HttpServer-1] Started.
2018-04-16T13:41:39.997-04:00 INFO  [JerseyService] Started Web Interface at <http://127.0.0.1:9000/>
2018-04-16T13:41:39.998-04:00 INFO  [ServiceManagerListener] Services are healthy
I would like to answer your question with a link to the elastic discourse:
Graylog is using the REST interface of Elasticsearch now - thats why you need to connect to Port 9200 (if you did not change tat in the Elasticsearch configuration.
If you bound something to a specific interface, it will only answer calls to that interface - not any othern. Unless you bound to multiple interfaces. But you bound Elasticsearch to a specific.
I addition remove all settings from the server.conf that are mentioned in the upgrade guide as beeing removed …
I don’t understand your point, in the last post I have set Graylog to use the REST interface of Elasticsearch on port 9200… have I not? My elasticsearch is bound to that same IP address. I suspect you may have been reading my post while I was still editing it.
Also, I did remove all the settings mentioned in your upgrade guide, they are commented out in the server.conf in my last post.
What I see: Server.log in the above post shows Graylog trying to reach Elasticsearch at 127.0.0.1:9200, but I have 10.1.115.2:9200 defined in server.conf for elasticsearch_host - so why is it using the loopback? Also note I have 10.115.2 bound in elasticsearch.yml - is there a new setting I need there?
What am I doing wrong?
No, you haven’t. The names of configuration settings do matter. :wink:
:scream_cat:
Thanks Jochen!!! Sometimes you just need a 2nd set of eyes…
I appreciate your help… :heart:
