Unknown source with filebeat
I just deployed a graylog server in version 3.0.2.
I created a beats input.
I added a client with filebeat version 7.5.1, in graylog webui I can see the logs showing up, but they are all showing source as unknown.
When I look at the differents fields I can see that the hostname of client is present in : filebeat_agent_name
filebeat_agent_hostname,
filebeat_host_name.
is there a way to configure graylog or filebeat in order to set the source filed to hostname ?
Best regards,
Here is an example filebeats collector configuration - your issue may be needing the first three/four lines in it… maybe post your collector configuration (properly formatted of course).
# Needed for Graylog
fields_under_root: true
output.logstash:
   hosts:
   - ${user.BeatsInput}
   ssl:
   verification_mode: none
path:
tags:
 - windows
filebeat:
  inputs:
    - type: log
      paths:
        - C:\Windows\Logs\DNSServer\dns.log
thank you for your feed back.
I wasn’t able to use this config on my filebeat. But we configured some extractors :
  "extractors": [
      "title": "LogLevel",
      "extractor_type": "regex",
      "converters": [],
      "order": 1,
      "cursor_strategy": "copy",
      "source_field": "message",
      "target_field": "log_level",
      "extractor_config": {
        "regex_value": "\\d\\d\\d\\d-\\d\\d-\\d\\d\\s\\d\\d:\\d\\d:\\d\\d\\s(?<loglevel>\\w+)\\s.*"
      "condition_type": "none",
      "condition_value": ""
      "title": "Timestamp",
      "converters": [
          "type": "date",
          "config": {
            "date_format": "yyyy-MM-dd HH:mm:ss",
            "time_zone": "Europe/Paris",
            "locale": "fr-FR"
      "order": 0,
      "target_field": "timestamp",
        "regex_value": "(?<date>\\d{4}-\\d{2}-\\d{2}\\s\\d\\d\\:\\d\\d\\:\\d\\d)"
      "title": "Source",
      "extractor_type": "copy_input",
      "converters": [],
      "order": 2,
      "source_field": "filebeat_host_name",
      "target_field": "source",
      "extractor_config": {},
  "version": "3.0.2"
on the input.
