Unknown Beats protocol
I found this entry on server.log :
2018-05-28T18:05:44.717+02:00 ERROR [NettyTransport] Error in Input [Beats/5b07cd46d68d6b60a6a6471c] (channel [id: 0xa53d8b46, /xx.xx.xx.xx:2576 :> /xx.xx.xx.xx:5044])
java.lang.Exception: Unknown beats protocol version: 0
        at org.graylog.plugins.beats.BeatsFrameDecoder.checkVersion(BeatsFrameDecoder.java:163) ~[?:?]
        at org.graylog.plugins.beats.BeatsFrameDecoder.decode(BeatsFrameDecoder.java:92) ~[?:?]
        at org.graylog.plugins.beats.BeatsFrameDecoder.decode(BeatsFrameDecoder.java:49) ~[?:?]
        at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:500) ~[graylog.jar:?]
        at org.jboss.netty.handler.codec.replay.ReplayingDecoder.cleanup(ReplayingDecoder.java:554) ~[graylog.jar:?]
        at org.jboss.netty.handler.codec.frame.FrameDecoder.channelDisconnected(FrameDecoder.java:365) ~[graylog.jar:?]
        at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:102) ~[graylog.jar:?]
        at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [graylog.jar:?]
        at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [graylog.jar:?]
        at org.jboss.netty.channel.SimpleChannelHandler.channelDisconnected(SimpleChannelHandler.java:199) [graylog.jar:?]
        at org.graylog2.plugin.inputs.util.ConnectionCounter.channelDisconnected(ConnectionCounter.java:49) [graylog.jar:?]
        at org.jboss.netty.channel.SimpleChannelHandler.handleUpstream(SimpleChannelHandler.java:120) [graylog.jar:?]
        at org.jboss.netty.channel.SimpleChannelUpstreamHandler.channelDisconnected(SimpleChannelUpstreamHandler.java:208) [graylog.jar:?]
        at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:102) [graylog.jar:?]
        at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559) [graylog.jar:?]
        at org.jboss.netty.channel.Channels.fireChannelDisconnected(Channels.java:396) [graylog.jar:?]
        at org.jboss.netty.channel.socket.nio.AbstractNioWorker.close(AbstractNioWorker.java:360) [graylog.jar:?]
        at org.jboss.netty.channel.socket.nio.NioServerSocketPipelineSink.handleAcceptedSocket(NioServerSocketPipelineSink.java:81) [graylog.jar:?]
        at org.jboss.netty.channel.socket.nio.NioServerSocketPipelineSink.eventSunk(NioServerSocketPipelineSink.java:36) [graylog.jar:?]
        at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:779) [graylog.jar:?]
        at org.jboss.netty.channel.SimpleChannelHandler.closeRequested(SimpleChannelHandler.java:334) [graylog.jar:?]
        at org.jboss.netty.channel.SimpleChannelHandler.handleDownstream(SimpleChannelHandler.java:260) [graylog.jar:?]
        at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:591) [graylog.jar:?]
        at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:784) [graylog.jar:?]
        at org.jboss.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108) [graylog.jar:?]
        at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:337) [graylog.jar:?]
        at org.jboss.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89) [graylog.jar:?]
        at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178) [graylog.jar:?]
        at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108) [graylog.jar:?]
        at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42) [graylog.jar:?]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_171]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_171]
        at java.lang.Thread.run(Thread.java:748) [?:1.8.0_171]
        at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:582) [graylog.jar:?]
        at org.jboss.netty.channel.Channels.close(Channels.java:812) [graylog.jar:?]
        at org.jboss.netty.channel.AbstractChannel.close(AbstractChannel.java:205) [graylog.jar:?]
        at org.graylog2.plugin.inputs.transports.NettyTransport$RawMessageHandler.exceptionCaught(NettyTransport.java:353) [graylog.jar:?]
        at org.jboss.netty.channel.SimpleChannelHandler.handleUpstream(SimpleChannelHandler.java:130) [graylog.jar:?]
        at org.jboss.netty.handler.codec.frame.FrameDecoder.exceptionCaught(FrameDecoder.java:377) [graylog.jar:?]
        at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:112) [graylog.jar:?]
        at org.jboss.netty.channel.SimpleChannelHandler.exceptionCaught(SimpleChannelHandler.java:156) [graylog.jar:?]
        at org.jboss.netty.channel.SimpleChannelUpstreamHandler.exceptionCaught(SimpleChannelUpstreamHandler.java:153) [graylog.jar:?]
        at org.graylog2.plugin.inputs.transports.NettyTransport$2$1.exceptionCaught(NettyTransport.java:210) [graylog.jar:?]
        at org.jboss.netty.channel.Channels.fireExceptionCaught(Channels.java:525) [graylog.jar:?]
        at org.jboss.netty.channel.AbstractChannelSink.exceptionCaught(AbstractChannelSink.java:48) [graylog.jar:?]
        at org.jboss.netty.channel.DefaultChannelPipeline.notifyHandlerException(DefaultChannelPipeline.java:658) [graylog.jar:?]
        at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:566) [graylog.jar:?]
 at org.jboss.netty.channel.SimpleChannelHandler.messageReceived(SimpleChannelHandler.java:142) [graylog.jar:?]
        at org.jboss.netty.channel.SimpleChannelHandler.handleUpstream(SimpleChannelHandler.java:88) [graylog.jar:?]
        at org.jboss.netty.handler.traffic.AbstractTrafficShapingHandler.messageReceived(AbstractTrafficShapingHandler.java:718) [graylog.jar:?]
        at org.jboss.netty.channel.SimpleChannelUpstreamHandler.messageReceived(SimpleChannelUpstreamHandler.java:124) [graylog.jar:?]
        at org.graylog2.plugin.inputs.util.PacketInformationDumper.messageReceived(PacketInformationDumper.java:51) [graylog.jar:?]
        at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70) [graylog.jar:?]
        at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:268) [graylog.jar:?]
        at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:255) [graylog.jar:?]
        at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88) [graylog.jar:?]
My filebeat version :
Package: filebeat
Status: install ok installed
Priority: extra
Section: default
Installed-Size: 49866
Maintainer: <@0e078882ff74>
Architecture: amd64
Version: 6.2.3
Filebeat parsing conf resume :
filebeat.prospectors:
- type: log
  enabled: true
  paths:
   - /var/log/pmta/bounces-*.csv
  fields:
   logtype: bounce
 #----------------------------- Logstash output --------------------------------
output.logstash:
  # The Logstash hosts
     hosts: ["XX.XX.XX.XX:5044"]
My graylog beats Input :
2018-05-30%2011_04_14-Graylog%20-%20Inputs
Same error append again, is it a configuration mistake ? But still no debug info for the pipeline.
2018-05-30T11:26:29.559+02:00 ERROR [NettyTransport] Error in Input [Beats/5b07cd46d68d6b60a6a6471c] (channel [id: 0xda5158f2, /xxxx:1803 => /xxxxx:5044])
java.lang.Exception: Unknown beats protocol version: 3
        at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:435) ~[graylog.jar:?]
        at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70) ~[graylog.jar:?]
   2018-05-30T11:26:29.564+02:00 ERROR [NettyTransport] Error in Input [Beats/5b07cd46d68d6b60a6a6471c] (channel [id: 0xda5158f2, /xxxxxx:1803 :> /xxxxx:5044])
@piellick Since this problem is different from trying to debug pipeline rules, I’ve split the posts into a new topic.
Check the configuration of the Beats client mentioned in the error message (e. g. 185.222.211.66 in the first post).
Ok it’s look same issue than this one :
https://github.com/Graylog2/graylog2-server/issues/4562
There appears to be no impact on functionality - a Flebeat forwarder is able to communicate and the logs appear correctly.
The same report for me, log export works well.
@jochen do you think this issue can impact my CSV pipeline processing ?
regards.
I don’t see how you come to that conclusion and without having checked your clients.
No.
Filebeat conf was allready checked :
Logs export works well. The root problem is still the CSV parsing value inside message over pipelines. Could you please restore the old post name ? :blush:
But something from that client is still sending invalid Beats packets to Graylog’s Beats input. You might want to investigate further.
The posts were split from the other topic, which still exists on its own: Plugin CSV function debug on pipeline - #13 by jochen
