Unattended installation - standalone
I’m trying to install a graylog instance on a single server (both datanode and graylog-server), on a Debian 12 VM.
I’d like to automate the pre-flights configuration that configure the certificates and the keystore (who said Ansible?), but I don’t have any success.
I’ve read this article but I don’t think it will allow me to skip the preflights stuff that has to be done.
If I wanted to configure the certificates in the keystore before launching the server and the datanode, what should I do ?
Hello @3isenHeiM,
Try using the selfsigned_startup = true within your server.conf, this will automate the setup of CA and certs
Thanks for the suggestion. I’ve set this option from a new installation, but it does not help.
I still have to go through the pre-flight configuration :confused:
Interesting, is there anything in the log on start up when that option is within the server.conf?
Here are the logs, I don’t see anything mentionning the creation of a CA or certificates.
server.log
2025-02-14T10:42:19.190+01:00 INFO  [ImmutableFeatureFlagsCollector] Following feature flags are used: {default properties file=[cloud_inputs=on, investigation_report_by_ai=on, data_tiering_cloud=off, composable_index_templates=off, preflight_web=on, data_node_migration=on, remote_reindex_migration=off, instant_archiving=off, configurable_value_units=on, new_report_creation=on, threat_coverage=on]}
2025-02-14T10:42:19.543+01:00 INFO  [CmdLineTool] Loaded plugin: AWS plugins 6.1.6+a644883 [org.graylog.aws.AWSPlugin]
2025-02-14T10:42:19.543+01:00 INFO  [CmdLineTool] Loaded plugin: Integrations 6.1.6+a644883 [org.graylog.integrations.IntegrationsPlugin]
2025-02-14T10:42:19.544+01:00 INFO  [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 6.1.6+a644883 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2025-02-14T10:42:19.544+01:00 INFO  [CmdLineTool] Loaded plugin: Elasticsearch 7 Support 6.1.6+a644883 [org.graylog.storage.elasticsearch7.Elasticsearch7Plugin]
2025-02-14T10:42:19.544+01:00 INFO  [CmdLineTool] Loaded plugin: OpenSearch 2 Support 6.1.6+a644883 [org.graylog.storage.opensearch2.OpenSearch2Plugin]
2025-02-14T10:42:19.556+01:00 INFO  [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:+UseG1GC -XX:-OmitStackTraceInFastThrow -Djdk.tls.acknowledgeCloseNotify=true -Dlog4j2.formatMsgNoLookups=true -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Dgraylog2.installation_source=deb
2025-02-14T10:42:19.657+01:00 INFO  [client] MongoClient with metadata {"driver": {"name": "mongo-java-driver|legacy", "version": "5.2.0"}, "os": {"type": "Linux", "name": "Linux", "architecture": "amd64", "version": "6.1.0-31-cloud-amd64"}, "platform": "Java/Eclipse Adoptium/17.0.14+7"} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, transportSettings=null, commandListeners=[], codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, CollectionCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, EnumCodecProvider{}, com.mongodb.client.model.mql.ExpressionCodecProvider@1a2bcd56, com.mongodb.Jep395RecordCodecProvider@68d7a2df, com.mongodb.KotlinCodecProvider@59dc36d4]}, loggerSettings=LoggerSettings{maxDocumentLength=1000}, clusterSettings={hosts=[localhost:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName='null', serverSelector='null', clusterListeners='[]', serverSelectionTimeout='30000 ms', localThreshold='15 ms'}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=[], maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverMonitoringMode=AUTO, serverListeners='[]', serverMonitorListeners='[]'}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName='null', compressorList=[], uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, dnsClient=null, inetAddressResolver=null, contextProvider=null, timeoutMS=null}
2025-02-14T10:42:19.667+01:00 INFO  [client] MongoClient with metadata {"driver": {"name": "mongo-java-driver", "version": "5.2.0"}, "os": {"type": "Linux", "name": "Linux", "architecture": "amd64", "version": "6.1.0-31-cloud-amd64"}, "platform": "Java/Eclipse Adoptium/17.0.14+7"} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, transportSettings=null, commandListeners=[], codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, CollectionCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, EnumCodecProvider{}, com.mongodb.client.model.mql.ExpressionCodecProvider@1a2bcd56, com.mongodb.Jep395RecordCodecProvider@68d7a2df, com.mongodb.KotlinCodecProvider@59dc36d4]}, loggerSettings=LoggerSettings{maxDocumentLength=1000}, clusterSettings={hosts=[localhost:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName='null', serverSelector='null', clusterListeners='[]', serverSelectionTimeout='30000 ms', localThreshold='15 ms'}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=[], maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverMonitoringMode=AUTO, serverListeners='[]', serverMonitorListeners='[]'}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName='null', compressorList=[], uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, dnsClient=null, inetAddressResolver=null, contextProvider=null, timeoutMS=null}
2025-02-14T10:42:19.687+01:00 INFO  [cluster] Waiting for server to become available for operation with ID 3. Remaining time: 29997 ms. Selector: ReadPreferenceServerSelector{readPreference=primary}, topology description: {type=UNKNOWN, servers=[{address=localhost:27017, type=UNKNOWN, state=CONNECTING}].
2025-02-14T10:42:19.698+01:00 INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, cryptd=false, state=CONNECTED, ok=true, minWireVersion=0, maxWireVersion=21, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=17929021, minRoundTripTimeNanos=0}
2025-02-14T10:42:19.731+01:00 INFO  [MongoDBPreflightCheck] Connected to MongoDB version 7.0.16
2025-02-14T10:42:20.001+01:00 INFO  [client] MongoClient with metadata {"driver": {"name": "mongo-java-driver|legacy", "version": "5.2.0"}, "os": {"type": "Linux", "name": "Linux", "architecture": "amd64", "version": "6.1.0-31-cloud-amd64"}, "platform": "Java/Eclipse Adoptium/17.0.14+7"} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, transportSettings=null, commandListeners=[], codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, CollectionCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, EnumCodecProvider{}, com.mongodb.client.model.mql.ExpressionCodecProvider@1a2bcd56, com.mongodb.Jep395RecordCodecProvider@68d7a2df, com.mongodb.KotlinCodecProvider@59dc36d4]}, loggerSettings=LoggerSettings{maxDocumentLength=1000}, clusterSettings={hosts=[localhost:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName='null', serverSelector='null', clusterListeners='[]', serverSelectionTimeout='30000 ms', localThreshold='15 ms'}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=[], maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverMonitoringMode=AUTO, serverListeners='[]', serverMonitorListeners='[]'}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName='null', compressorList=[], uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, dnsClient=null, inetAddressResolver=null, contextProvider=null, timeoutMS=null}
2025-02-14T10:42:20.005+01:00 INFO  [client] MongoClient with metadata {"driver": {"name": "mongo-java-driver", "version": "5.2.0"}, "os": {"type": "Linux", "name": "Linux", "architecture": "amd64", "version": "6.1.0-31-cloud-amd64"}, "platform": "Java/Eclipse Adoptium/17.0.14+7"} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, transportSettings=null, commandListeners=[], codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, CollectionCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, EnumCodecProvider{}, com.mongodb.client.model.mql.ExpressionCodecProvider@1a2bcd56, com.mongodb.Jep395RecordCodecProvider@68d7a2df, com.mongodb.KotlinCodecProvider@59dc36d4]}, loggerSettings=LoggerSettings{maxDocumentLength=1000}, clusterSettings={hosts=[localhost:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName='null', serverSelector='null', clusterListeners='[]', serverSelectionTimeout='30000 ms', localThreshold='15 ms'}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=[], maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverMonitoringMode=AUTO, serverListeners='[]', serverMonitorListeners='[]'}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName='null', compressorList=[], uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, dnsClient=null, inetAddressResolver=null, contextProvider=null, timeoutMS=null}
2025-02-14T10:42:20.006+01:00 INFO  [cluster] Waiting for server to become available for operation with ID 11. Remaining time: 29999 ms. Selector: ReadPreferenceServerSelector{readPreference=primary}, topology description: {type=UNKNOWN, servers=[{address=localhost:27017, type=UNKNOWN, state=CONNECTING}].
2025-02-14T10:42:20.009+01:00 INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, cryptd=false, state=CONNECTED, ok=true, minWireVersion=0, maxWireVersion=21, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=3181848, minRoundTripTimeNanos=0}
2025-02-14T10:42:20.097+01:00 INFO  [IndexerDiscoveryProvider] No indexer hosts configured, using fallback http://127.0.0.1:9200
2025-02-14T10:42:20.309+01:00 INFO  [ServerBootstrap] Running 2 migrations...
2025-02-14T10:42:20.327+01:00 INFO  [ServerBootstrap] Fresh installation detected, starting configuration webserver
2025-02-14T10:42:20.336+01:00 INFO  [PeriodicalsService] Starting 3 periodicals ...
2025-02-14T10:42:20.337+01:00 INFO  [Periodicals] Starting [org.graylog2.bootstrap.preflight.GraylogCertificateProvisioningPeriodical] periodical in [2s], polling every [2s].
2025-02-14T10:42:20.338+01:00 INFO  [Periodicals] Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
2025-02-14T10:42:20.343+01:00 INFO  [Periodicals] Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
2025-02-14T10:42:20.597+01:00 INFO  [Version] HV000001: Hibernate Validator null
2025-02-14T10:42:20.727+01:00 INFO  [NetworkListener] Started listener bound to [0.0.0.0:9000]
2025-02-14T10:42:20.727+01:00 INFO  [HttpServer] [HttpServer] Started.
2025-02-14T10:42:20.730+01:00 INFO  [PreflightJerseyService]
It seems you are starting Graylog for the first time. To set up a fresh install, a setup interface has
been started. You must log in to it to perform the initial configuration and continue.
Initial configuration is accessible at 0.0.0.0:9000, with username 'admin' and password 'eQgUfTbiOk'.
Try clicking on http://admin:eQgUfTbiOk@0.0.0.0:9000
