Hi!
First time Graylog user and having issues getting to the web interface.
I am hosting the Graylog server in a private subnet on a public cloud. I have added this server as a WireGuard peer as well.
I am able to ping my server from a device another device connected to WireGuard. I am not able to curl or telnet http://192.168.100.3:9000
– Some info –
- Graylog server IP =
10.20.3.2 - WireGuard peer IP =
192.168.100.3 - The HTTP settings in
server.conf: - http_bind_address =
0.0.0.0:9000 - OS Information: Ubuntu 22.04.5 LTS
mongodb,graylog-server, andgraylog-datanodeare all actively running (via systemctl status)- Running the latest Graylog version
sudo netstat -tnlp | grep :9000
tcp6 0 0 :::9000 :::* LISTEN 5546/java
/var/log/graylog-server/server.log (output shown below - excluded the part that shows the crews)
2025-01-22T19:30:18.180Z INFO [IndexerDiscoveryProvider] No indexer hosts configured, using fallback http://127.0.0.1:9200
2025-01-22T19:30:18.644Z INFO [ServerBootstrap] Running 2 migrations...
2025-01-22T19:30:18.678Z INFO [ServerBootstrap] Fresh installation detected, starting configuration webserver
2025-01-22T19:30:18.684Z INFO [PeriodicalsService] Starting 3 periodicals ...
2025-01-22T19:30:18.689Z INFO [Periodicals] Starting [org.graylog2.bootstrap.preflight.GraylogCertificateProvisioningPeriodical] periodical in [2s], polling every [2s].
2025-01-22T19:30:18.690Z INFO [Periodicals] Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
2025-01-22T19:30:18.694Z INFO [Periodicals] Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
2025-01-22T19:30:19.347Z INFO [Version] HV000001: Hibernate Validator null
2025-01-22T19:30:19.641Z INFO [NetworkListener] Started listener bound to [0.0.0.0:9000]
2025-01-22T19:30:19.643Z INFO [HttpServer] [HttpServer] Started.
2025-01-22T19:30:19.646Z INFO [PreflightJerseyService]
I can’t think of anything else that might be relevant at the moment, so thank you in advance!
