Ubiquiti EdgeSwitch
Morning,
I am trying to get Graylogs to collect my EgdeSwitch logs. Does anyone know how to achieve this?
Do you know what type of input I should select, no matter what I select it always seems to go to Failed.
Thanks.
create a Syslog input on Graylog and point the logging output of syslog of the switch to this port/host you run the input.
As I have only unify hardware this is a few commands on the controller for the setup and I did not know about the options the edge switch has.
Hey Jan… still not working. Do I use Syslog TCP or Syslog UDP.
I set my edgeswitch logging host to 172.16.0.183 (gray log server) port 5140.
Every time I try to start the Input it goes straight to failed.
  • allow_override_date:
true
  • bind_address:
172.16.1.231
  • expand_structured_data:
false
  • force_rdns:
false
  • override_source:
<empty>
  • port:
5140
  • recv_buffer_size:
262144
  • store_full_message:
false
you should check your Graylog server.log (tail -f on that when starting the input) for the reason why the input can’t be started.
The default file location depends on your Installation and we wrote them down in the documentation: http://docs.graylog.org/en/2.4/pages/configuration/file_location.html
Sorry not great with linux. How do I see the log file.
I am running the Graylog template downloaded from your site… log in with ubuntu ubuntu.
Cheers.
so you run the OVA (what is an Omnibus Package)
Your Logfile is located in /var/log/graylog/server/with the name current and to watch the logfile you can run tail -f /var/log/graylog/server/current to see the log and follow it - then leave the terminal open in backround and start the input.
Jan, thanks for that information. But it didn’t really help. Error below, but posted rest of log file below.
2018-08-12_05:11:50.31569 INFO  [InputStateListener] Input [Syslog UDP/5b6eb21ebe9d5c03240981c0] is now FAILED
2018-08-12_05:11:39.42404 at sun.reflect.GeneratedMethodAccessor88.invoke(Unknown Source) ~[?:?]
2018-08-12_05:11:39.42500 at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_172]
2018-08-12_05:11:39.42538 at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_172]
2018-08-12_05:11:39.42597 at com.google.common.eventbus.Subscriber.invokeSubscriberMethod(Subscriber.java:91) ~[graylog.jar:?]
2018-08-12_05:11:39.42645 at com.google.common.eventbus.Subscriber$SynchronizedSubscriber.invokeSubscriberMethod(Subscriber.java:150) ~[graylog.jar:?]
2018-08-12_05:11:39.42706 at com.google.common.eventbus.Subscriber$1.run(Subscriber.java:76) [graylog.jar:?]
2018-08-12_05:11:39.42747 at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:176) [graylog.jar:?]
2018-08-12_05:11:39.42817 at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_172]
2018-08-12_05:11:39.42854 at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_172]
2018-08-12_05:11:39.42928 at java.lang.Thread.run(Thread.java:748) [?:1.8.0_172]
2018-08-12_05:11:45.30940 ERROR [Cluster] Couldn't read cluster health for indices [graylog_*] (No route to host (Host unreachable))
2018-08-12_05:11:45.30982 INFO [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2018-08-12_05:11:50.23189 INFO [InputStateListener] Input [Syslog UDP/5b6eb21ebe9d5c03240981c0] is now STOPPING
2018-08-12_05:11:50.24979 INFO [InputStateListener] Input [Syslog UDP/5b6eb21ebe9d5c03240981c0] is now STOPPED
2018-08-12_05:11:50.25197 INFO [InputStateListener] Input [Syslog UDP/5b6eb21ebe9d5c03240981c0] is now STARTING
2018-08-12_05:11:50.25241 INFO [InputStateListener] Input [Syslog UDP/5b6eb21ebe9d5c03240981c0] is now TERMINATED
2018-08-12_05:11:50.25430 ERROR [NettyTransport] Error in Input [Syslog UDP/5b6eb21ebe9d5c03240981c0] (channel [id: 0x561e0400])
2018-08-12_05:11:50.25452 java.net.BindException: Cannot assign requested address
2018-08-12_05:11:50.25500 at sun.nio.ch.Net.bind0(Native Method) ~[?:1.8.0_172]
2018-08-12_05:11:50.25654 at sun.nio.ch.Net.bind(Net.java:433) ~[?:1.8.0_172]
2018-08-12_05:11:50.25727 at sun.nio.ch.DatagramChannelImpl.bind(DatagramChannelImpl.java:691) ~[?:1.8.0_172]
2018-08-12_05:11:50.25798 at sun.nio.ch.DatagramSocketAdaptor.bind(DatagramSocketAdaptor.java:91) ~[?:1.8.0_172]
2018-08-12_05:11:50.26372 at org.jboss.netty.channel.socket.nio.NioDatagramPipelineSink.bind(NioDatagramPipelineSink.java:129) [graylog.jar:?]
2018-08-12_05:11:50.26403 at org.jboss.netty.channel.socket.nio.NioDatagramPipelineSink.eventSunk(NioDatagramPipelineSink.java:77) [graylog.jar:?]
2018-08-12_05:11:50.26446 at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:779) [graylog.jar:?]
2018-08-12_05:11:50.26496 at org.jboss.netty.channel.SimpleChannelHandler.bindRequested(SimpleChannelHandler.java:299) [graylog.jar:?]
2018-08-12_05:11:50.26534 at org.jboss.netty.channel.SimpleChannelHandler.handleDownstream(SimpleChannelHandler.java:265) [graylog.jar:?]
2018-08-12_05:11:50.26601 at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:591) [graylog.jar:?]
2018-08-12_05:11:50.26644 at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:784) [graylog.jar:?]
2018-08-12_05:11:50.26711 at org.jboss.netty.channel.SimpleChannelHandler.bindRequested(SimpleChannelHandler.java:299) [graylog.jar:?]
2018-08-12_05:11:50.26751 at org.jboss.netty.channel.SimpleChannelHandler.handleDownstream(SimpleChannelHandler.java:265) [graylog.jar:?]
2018-08-12_05:11:50.26800 at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:591) [graylog.jar:?]
2018-08-12_05:11:50.26844 at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:582) [graylog.jar:?]
2018-08-12_05:11:50.26922 at org.jboss.netty.channel.Channels.bind(Channels.java:561) [graylog.jar:?]
2018-08-12_05:11:50.26965 at org.jboss.netty.channel.AbstractChannel.bind(AbstractChannel.java:197) [graylog.jar:?]
2018-08-12_05:11:50.27027 at org.jboss.netty.bootstrap.ConnectionlessBootstrap.bind(ConnectionlessBootstrap.java:198) [graylog.jar:?]
2018-08-12_05:11:50.27069 at org.graylog2.plugin.inputs.transports.NettyTransport.launch(NettyTransport.java:136) [graylog.jar:?]
2018-08-12_05:11:50.27116 at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:155) [graylog.jar:?]
2018-08-12_05:11:50.27153 at org.graylog2.shared.inputs.InputLauncher$1.run(InputLauncher.java:84) [graylog.jar:?]
2018-08-12_05:11:50.27224 at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:176) [graylog.jar:?]
2018-08-12_05:11:50.27274 at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_172]
2018-08-12_05:11:50.27615 at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_172]
2018-08-12_05:11:50.27637 at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_172]
2018-08-12_05:11:50.27681 at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_172]
2018-08-12_05:11:50.27740 at java.lang.Thread.run(Thread.java:748) [?:1.8.0_172]
2018-08-12_05:11:50.27785 ERROR [InputLauncher] The [org.graylog2.inputs.syslog.udp.SyslogUDPInput] input with ID &lt;5b6eb21ebe9d5c03240981c0&gt; misfired. Reason: Cannot assign requested address.
2018-08-12_05:11:50.27824 org.graylog2.plugin.inputs.MisfireException: org.graylog2.plugin.inputs.MisfireException: org.jboss.netty.channel.ChannelException: Failed to bind to: /172.16.1.231:5140
2018-08-12_05:11:50.27884 at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:158) ~[graylog.jar:?]
2018-08-12_05:11:50.27951 at org.graylog2.shared.inputs.InputLauncher$1.run(InputLauncher.java:84) [graylog.jar:?]
2018-08-12_05:11:50.28006 at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:176) [graylog.jar:?]
2018-08-12_05:11:50.28047 at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_172]
2018-08-12_05:11:50.28543 at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_172]
2018-08-12_05:11:50.28611 at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_172]
2018-08-12_05:11:50.28643 at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_172]
2018-08-12_05:11:50.28689 at java.lang.Thread.run(Thread.java:748) [?:1.8.0_172]
2018-08-12_05:11:50.28768 Caused by: org.graylog2.plugin.inputs.MisfireException: org.jboss.netty.channel.ChannelException: Failed to bind to: /172.16.1.231:5140
2018-08-12_05:11:50.28807 at org.graylog2.plugin.inputs.transports.NettyTransport.launch(NettyTransport.java:155) ~[graylog.jar:?]
2018-08-12_05:11:50.28851 at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:155) ~[graylog.jar:?]
2018-08-12_05:11:50.28925 ... 7 more
2018-08-12_05:11:50.28986 Caused by: org.jboss.netty.channel.ChannelException: Failed to bind to: /172.16.1.231:5140
2018-08-12_05:11:50.29027 at org.jboss.netty.bootstrap.ConnectionlessBootstrap.bind(ConnectionlessBootstrap.java:204) ~[graylog.jar:?]
2018-08-12_05:11:50.29093 at org.graylog2.plugin.inputs.transports.NettyTransport.launch(NettyTransport.java:136) ~[graylog.jar:?]
2018-08-12_05:11:50.29156 at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:155) ~[graylog.jar:?]
2018-08-12_05:11:50.29200 ... 7 more
2018-08-12_05:11:50.29258 Caused by: java.net.BindException: Cannot assign requested address
2018-08-12_05:11:50.29733 at sun.nio.ch.Net.bind0(Native Method) ~[?:1.8.0_172]
2018-08-12_05:11:50.29775 at sun.nio.ch.Net.bind(Net.java:433) ~[?:1.8.0_172]
2018-08-12_05:11:50.29842 at sun.nio.ch.DatagramChannelImpl.bind(DatagramChannelImpl.java:691) ~[?:1.8.0_172]
2018-08-12_05:11:50.29882 at sun.nio.ch.DatagramSocketAdaptor.bind(DatagramSocketAdaptor.java:91) ~[?:1.8.0_172]
2018-08-12_05:11:50.29952 at org.jboss.netty.channel.socket.nio.NioDatagramPipelineSink.bind(NioDatagramPipelineSink.java:129) ~[graylog.jar:?]
2018-08-12_05:11:50.29993 at org.jboss.netty.channel.socket.nio.NioDatagramPipelineSink.eventSunk(NioDatagramPipelineSink.java:77) ~[graylog.jar:?]
2018-08-12_05:11:50.30069 at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:779) ~[graylog.jar:?]
2018-08-12_05:11:50.30113 at org.jboss.netty.channel.SimpleChannelHandler.bindRequested(SimpleChannelHandler.java:299) ~[graylog.jar:?]
2018-08-12_05:11:50.30185 at org.jboss.netty.channel.SimpleChannelHandler.handleDownstream(SimpleChannelHandler.java:265) ~[graylog.jar:?]
2018-08-12_05:11:50.30228 at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:591) ~[graylog.jar:?]
2018-08-12_05:11:50.30287 at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:784) ~[graylog.jar:?]
2018-08-12_05:11:50.30326 at org.jboss.netty.channel.SimpleChannelHandler.bindRequested(SimpleChannelHandler.java:299) ~[graylog.jar:?]
2018-08-12_05:11:50.30368 at org.jboss.netty.channel.SimpleChannelHandler.handleDownstream(SimpleChannelHandler.java:265) ~[graylog.jar:?]
2018-08-12_05:11:50.30751 at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:591) ~[graylog.jar:?]
2018-08-12_05:11:50.30822 at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:582) ~[graylog.jar:?]
2018-08-12_05:11:50.30863 at org.jboss.netty.channel.Channels.bind(Channels.java:561) ~[graylog.jar:?]
2018-08-12_05:11:50.31334 at org.jboss.netty.channel.AbstractChannel.bind(AbstractChannel.java:197) ~[graylog.jar:?]
2018-08-12_05:11:50.31379 at org.jboss.netty.bootstrap.ConnectionlessBootstrap.bind(ConnectionlessBootstrap.java:198) ~[graylog.jar:?]
2018-08-12_05:11:50.31430 at org.graylog2.plugin.inputs.transports.NettyTransport.launch(NettyTransport.java:136) ~[graylog.jar:?]
2018-08-12_05:11:50.31472 at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:155) ~[graylog.jar:?]
2018-08-12_05:11:50.31536 ... 7 more
^Cubuntu@graylog:~$ sudo tail -f /var/log/graylog/server/current
2018-08-12_05:12:15.74603 WARN [V20161130141500_DefaultStreamRecalcIndexRanges] Interrupted or timed out waiting for Elasticsearch cluster, checking again.
2018-08-12_05:12:51.32331 INFO [InputStateListener] Input [Syslog UDP/5b6eb21ebe9d5c03240981c0] is now STOPPING
2018-08-12_05:12:51.32913 INFO [InputStateListener] Input [Syslog UDP/5b6eb21ebe9d5c03240981c0] is now STOPPED
2018-08-12_05:12:51.36298 ERROR [NettyTransport] Error in Input [Syslog UDP/5b6eb21ebe9d5c03240981c0] (channel [id: 0x42cc7e38])
2018-08-12_05:12:51.36347 java.net.BindException: Cannot assign requested address
2018-08-12_05:12:51.36394 at sun.nio.ch.Net.bind0(Native Method) ~[?:1.8.0_172]
2018-08-12_05:12:51.36498 at sun.nio.ch.Net.bind(Net.java:433) ~[?:1.8.0_172]
2018-08-12_05:12:51.36548 at sun.nio.ch.DatagramChannelImpl.bind(DatagramChannelImpl.java:691) ~[?:1.8.0_172]
2018-08-12_05:12:51.36656 at sun.nio.ch.DatagramSocketAdaptor.bind(DatagramSocketAdaptor.java:91) ~[?:1.8.0_172]
2018-08-12_05:12:51.36733 at org.jboss.netty.channel.socket.nio.NioDatagramPipelineSink.bind(NioDatagramPipelineSink.java:129) [graylog.jar:?]
2018-08-12_05:12:51.36806 at org.jboss.netty.channel.socket.nio.NioDatagramPipelineSink.eventSunk(NioDatagramPipelineSink.java:77) [graylog.jar:?]
2018-08-12_05:12:51.38104 at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:779) [graylog.jar:?]
2018-08-12_05:12:51.38112 at org.jboss.netty.channel.SimpleChannelHandler.bindRequested(SimpleChannelHandler.java:299) [graylog.jar:?]
2018-08-12_05:12:51.38115 at org.jboss.netty.channel.SimpleChannelHandler.handleDownstream(SimpleChannelHandler.java:265) [graylog.jar:?]
2018-08-12_05:12:51.38117 at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:591) [graylog.jar:?]
2018-08-12_05:12:51.38119 at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:784) [graylog.jar:?]
2018-08-12_05:12:51.38120 at org.jboss.netty.channel.SimpleChannelHandler.bindRequested(SimpleChannelHandler.java:299) [graylog.jar:?]
2018-08-12_05:12:51.38122 at org.jboss.netty.channel.SimpleChannelHandler.handleDownstream(SimpleChannelHandler.java:265) [graylog.jar:?]
2018-08-12_05:12:51.38124 at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:591) [graylog.jar:?]
2018-08-12_05:12:51.38125 at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:582) [graylog.jar:?]
2018-08-12_05:12:51.38129 at org.jboss.netty.channel.Channels.bind(Channels.java:561) [graylog.jar:?]
2018-08-12_05:12:51.38131 at org.jboss.netty.channel.AbstractChannel.bind(AbstractChannel.java:197) [graylog.jar:?]
2018-08-12_05:12:51.38154 at org.jboss.netty.bootstrap.ConnectionlessBootstrap.bind(ConnectionlessBootstrap.java:198) [graylog.jar:?]
2018-08-12_05:12:51.38224 at org.graylog2.plugin.inputs.transports.NettyTransport.launch(NettyTransport.java:136) [graylog.jar:?]
2018-08-12_05:12:51.38283 at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:155) [graylog.jar:?]
2018-08-12_05:12:51.38715 at org.graylog2.shared.inputs.InputLauncher$1.run(InputLauncher.java:84) [graylog.jar:?]
2018-08-12_05:12:51.39344 at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:176) [graylog.jar:?]
2018-08-12_05:12:51.39408 at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_172]
2018-08-12_05:12:51.39461 at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_172]
2018-08-12_05:12:51.39508 at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_172]
2018-08-12_05:12:51.39557 at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_172]
2018-08-12_05:12:51.39591 at java.lang.Thread.run(Thread.java:748) [?:1.8.0_172]
2018-08-12_05:12:51.39654 ERROR [InputLauncher] The [org.graylog2.inputs.syslog.udp.SyslogUDPInput] input with ID &lt;5b6eb21ebe9d5c03240981c0&gt; misfired. Reason: Cannot assign requested address.
2018-08-12_05:12:51.39692 org.graylog2.plugin.inputs.MisfireException: org.graylog2.plugin.inputs.MisfireException: org.jboss.netty.channel.ChannelException: Failed to bind to: /172.16.1.231:5140
2018-08-12_05:12:51.39770 at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:158) ~[graylog.jar:?]
2018-08-12_05:12:51.39819 at org.graylog2.shared.inputs.InputLauncher$1.run(InputLauncher.java:84) [graylog.jar:?]
2018-08-12_05:12:51.40136 at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:176) [graylog.jar:?]
2018-08-12_05:12:51.40228 at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_172]
2018-08-12_05:12:51.40303 at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_172]
2018-08-12_05:12:51.40399 at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_172]
2018-08-12_05:12:51.40656 at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_172]
2018-08-12_05:12:51.40731 at java.lang.Thread.run(Thread.java:748) [?:1.8.0_172]
2018-08-12_05:12:51.41360 Caused by: org.graylog2.plugin.inputs.MisfireException: org.jboss.netty.channel.ChannelException: Failed to bind to: /172.16.1.231:5140
2018-08-12_05:12:51.41419 at org.graylog2.plugin.inputs.transports.NettyTransport.launch(NettyTransport.java:155) ~[graylog.jar:?]
2018-08-12_05:12:51.41718 at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:155) ~[graylog.jar:?]
2018-08-12_05:12:51.41775 ... 7 more
2018-08-12_05:12:51.41844 Caused by: org.jboss.netty.channel.ChannelException: Failed to bind to: /172.16.1.231:5140
2018-08-12_05:12:51.41896 at org.jboss.netty.bootstrap.ConnectionlessBootstrap.bind(ConnectionlessBootstrap.java:204) ~[graylog.jar:?]
2018-08-12_05:12:51.41962 at org.graylog2.plugin.inputs.transports.NettyTransport.launch(NettyTransport.java:136) ~[graylog.jar:?]
2018-08-12_05:12:51.42011 at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:155) ~[graylog.jar:?]
2018-08-12_05:12:51.42543 ... 7 more
2018-08-12_05:12:51.42614 Caused by: java.net.BindException: Cannot assign requested address
2018-08-12_05:12:51.42735 at sun.nio.ch.Net.bind0(Native Method) ~[?:1.8.0_172]
2018-08-12_05:12:51.42791 at sun.nio.ch.Net.bind(Net.java:433) ~[?:1.8.0_172]
2018-08-12_05:12:51.42853 at sun.nio.ch.DatagramChannelImpl.bind(DatagramChannelImpl.java:691) ~[?:1.8.0_172]
2018-08-12_05:12:51.42906 at sun.nio.ch.DatagramSocketAdaptor.bind(DatagramSocketAdaptor.java:91) ~[?:1.8.0_172]
2018-08-12_05:12:51.43058 at org.jboss.netty.channel.socket.nio.NioDatagramPipelineSink.bind(NioDatagramPipelineSink.java:129) ~[graylog.jar:?]
2018-08-12_05:12:51.43106 at org.jboss.netty.channel.socket.nio.NioDatagramPipelineSink.eventSunk(NioDatagramPipelineSink.java:77) ~[graylog.jar:?]
2018-08-12_05:12:51.43165 at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:779) ~[graylog.jar:?]
2018-08-12_05:12:51.43216 at org.jboss.netty.channel.SimpleChannelHandler.bindRequested(SimpleChannelHandler.java:299) ~[graylog.jar:?]
2018-08-12_05:12:51.43727 at org.jboss.netty.channel.SimpleChannelHandler.handleDownstream(SimpleChannelHandler.java:265) ~[graylog.jar:?]
2018-08-12_05:12:51.43784 at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:591) ~[graylog.jar:?]
2018-08-12_05:12:51.43849 at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:784) ~[graylog.jar:?]
2018-08-12_05:12:51.43898 at org.jboss.netty.channel.SimpleChannelHandler.bindRequested(SimpleChannelHandler.java:299) ~[graylog.jar:?]
2018-08-12_05:12:51.43994 at org.jboss.netty.channel.SimpleChannelHandler.handleDownstream(SimpleChannelHandler.java:265) ~[graylog.jar:?]
2018-08-12_05:12:51.44060 at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:591) ~[graylog.jar:?]
2018-08-12_05:12:51.44132 at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:582) ~[graylog.jar:?]
2018-08-12_05:12:51.44197 at org.jboss.netty.channel.Channels.bind(Channels.java:561) ~[graylog.jar:?]
2018-08-12_05:12:51.44447 at org.jboss.netty.channel.AbstractChannel.bind(AbstractChannel.java:197) ~[graylog.jar:?]
2018-08-12_05:12:51.44652 at org.jboss.netty.bootstrap.ConnectionlessBootstrap.bind(ConnectionlessBootstrap.java:198) ~[graylog.jar:?]
2018-08-12_05:12:51.44984 at org.graylog2.plugin.inputs.transports.NettyTransport.launch(NettyTransport.java:136) ~[graylog.jar:?]
2018-08-12_05:12:51.44989 at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:155) ~[graylog.jar:?]
2018-08-12_05:12:51.44991 ... 7 more
2018-08-12_05:12:51.44993 INFO [InputStateListener] Input [Syslog UDP/5b6eb21ebe9d5c03240981c0] is now STARTING
2018-08-12_05:12:51.44994 INFO [InputStateListener] Input [Syslog UDP/5b6eb21ebe9d5c03240981c0] is now FAILED
2018-08-12_05:12:51.44996 INFO [InputStateListener] Input [Syslog UDP/5b6eb21ebe9d5c03240981c0] is now TERMINATED
It looks like the configured IP 172.16.1.231 is not available on the server.
