Trying to enable SSL
I mostly followed these instructions to create to configure SSL: http://www.hospitableit.com/howto/setting-up-a-centralised-log-server-using-graylog-on-ubuntu-16-04-lts-part-two/
  • openssl genrsa -aes128 -out graylog.key 4096
  • openssl req -sha256 -key graylog.key -new -out graylog.csr -config graylog.cnf
  • openssl pkcs8 -in graylog.key -topk8 -out graylogPKCS8.key
  • keytool -import -trustcacerts -file /etc/ssl/certs/graylog.crt -alias ComodoCA -keystore /etc/graylog/cacerts.jks
  • keytool -list -v -keystore /etc/graylog/cacerts.jks
Graylog isn’t starting and I’m getting this error. Seems like I have all the files in place. Any advice?
2020-02-18T09:07:45.713-05:00 ERROR [ServerBootstrap] Graylog startup failed. Exiting. Exception was:
	at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.checkHealthy(ServiceManager.java:741) ~[graylog.jar:?]
	at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.awaitHealthy(ServiceManager.java:553) ~[graylog.jar:?]
	at com.google.common.util.concurrent.ServiceManager.awaitHealthy(ServiceManager.java:314) ~[graylog.jar:?]
	at org.graylog2.bootstrap.ServerBootstrap.startCommand(ServerBootstrap.java:148) [graylog.jar:?]
	at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:210) [graylog.jar:?]
	Suppressed: com.google.common.util.concurrent.ServiceManager$FailedService: JerseyService [FAILED]
	Caused by: java.io.IOException: ObjectIdentifier() -- data isn't an object ID (tag = 48)
		at sun.security.util.ObjectIdentifier.<init>(ObjectIdentifier.java:257) ~[?:1.8.0_242]
		at sun.security.util.DerInputStream.getOID(DerInputStream.java:314) ~[?:1.8.0_242]
		at com.sun.crypto.provider.PBES2Parameters.engineInit(PBES2Parameters.java:267) ~[sunjce_provider.jar:1.8.0_242]
		at java.security.AlgorithmParameters.init(AlgorithmParameters.java:293) ~[?:1.8.0_242]
		at sun.security.x509.AlgorithmId.decodeParams(AlgorithmId.java:132) ~[?:1.8.0_242]
		at sun.security.x509.AlgorithmId.<init>(AlgorithmId.java:114) ~[?:1.8.0_242]
		at sun.security.x509.AlgorithmId.parse(AlgorithmId.java:372) ~[?:1.8.0_242]
		at javax.crypto.EncryptedPrivateKeyInfo.<init>(EncryptedPrivateKeyInfo.java:95) ~[?:1.8.0_242]
		at org.graylog2.shared.security.tls.PemKeyStore.generateKeySpec(PemKeyStore.java:69) ~[graylog.jar:?]
		at org.graylog2.shared.security.tls.PemKeyStore.buildKeyStore(PemKeyStore.java:98) ~[graylog.jar:?]
		at org.graylog2.shared.initializers.JerseyService.buildSslEngineConfigurator(JerseyService.java:347) ~[graylog.jar:?]
		at org.graylog2.shared.initializers.JerseyService.startUpApi(JerseyService.java:172) ~[graylog.jar:?]
		at org.graylog2.shared.initializers.JerseyService.startUp(JerseyService.java:146) ~[graylog.jar:?]
		at com.google.common.util.concurrent.AbstractIdleService$DelegateService$1.run(AbstractIdleService.java:62) ~[graylog.jar:?]
		at com.google.common.util.concurrent.Callables$4.run(Callables.java:119) ~[graylog.jar:?]
		at java.lang.Thread.run(Thread.java:748) ~[?:1.8.0_242]
2020-02-18T09:07:45.715-05:00 INFO  [Server] SIGNAL received. Shutting down.
2020-02-18T09:07:45.719-05:00 INFO  [GracefulShutdown] Graceful shutdown initiated.
2020-02-18T09:07:45.719-05:00 INFO  [GracefulShutdown] Node status: [Halting [LB:DEAD]]. Waiting <3sec> for possible load balancers to recognize state change.
2020-02-18T09:07:49.721-05:00 INFO  [GracefulShutdown] Goodbye.
he @atrof
and how did you configured http_* parameters in Graylog?
root@graylog:~# cat /etc/graylog/server/server.conf | grep http
# as defined in https://docs.oracle.com/javase/specs/jls/se8/html/jls-3.html#jls-3.3, using the \u prefix.
#http_bind_address = 127.0.0.1:9000
http_bind_address = 172.17.1.5:9000
#http_publish_uri = http://192.168.1.1:9000/
http_publish_uri = https://graylog.domainname_here.com:9000/
# Default: $http_publish_uri
#http_external_uri =
http_external_url = https://graylog.domainname_here.com:9000/
#http_enable_cors = false
#http_enable_gzip = false
#http_max_header_size = 8192
#http_thread_pool_size = 16
#http_enable_tls = true
http_tls_cert_file = /etc/ssl/certs/graylog.crt
http_tls_key_file = /etc/graylog/graylog-web8.key
http_tls_key_password = secret_here
did you made the suggested changes to the Graylog Startup script like written in the howto?
Sorry, not sure what you’re referring to. The JVM settings in the documentation, or the JAVA_OPTS in the tutorial above, or something else? Thanks.
I refer to the tutorial you have used …
I ran one more conversion on the pkcs8 key. I noticed it was encrypted, so I made it unencrypted with this command and that worked:
openssl pkcs8 -in graylogPKCS8.key -topk8 -nocrypt -out pkcs8-plain.pem
